new brake rotors gets hot?
Old 05-15-09, 04:35 PM
SC300_704
SC300_704's Avatar
Default new brake rotors gets hot?
i just installed a new rotor and pads on the rear driver side today and just notice it awhile ago when i got home from driving on the interstate. when i opened the door i smell something burning, it was smoking a little and the new rotor turned to a purple/yellowish color..is this normal?
Old 05-15-09, 06:38 PM
RyanV
RyanV's Avatar
I'm no brake expert, but it sounds like a sticky caliper to me. Shouldn't get so hot that you can smell it, and see smoke.
I had a front stick, but it did not smoke. The car was driving really funky though, I ended up getting it towed.
Check the parking brake adjustment because you installed a new rotor, and remove the pads and see if the piston is seized up maybe?
Old 05-16-09, 12:43 PM
rustednail
rustednail's Avatar
sounds like a sticking caliper. You will have to replace it.
Old 05-16-09, 12:46 PM
GSteg
GSteg's Avatar
That's normal for new brakes/pads to do that.
It's only a problem if the burning smell is still there after a few days.
All the brake jobs I've done have the same results...burning smell (and slight smoke) at first, but then it goes away after a few days.
Old 05-16-09, 12:47 PM
Vortes
Vortes's Avatar
did you use brake cleaner or whatever on the rotor to get the anti rust covering off?
Old 05-16-09, 03:01 PM
GSteg
GSteg's Avatar
It wouldn't matter since he installed new rotors
Old 05-16-09, 03:07 PM
RyanV
RyanV's Avatar
Good point..rotors do come new with an anti corrosion liquid on them. Gotta hit them with brake cleaner.
I personally have never seen brakes smoke after I changed them out. I would say the smell could be normal, but smoke
Old 05-16-09, 04:49 PM
SC300_704
SC300_704's Avatar
no i didn't clean the rotors w/ brake cleaners..i guess i must've messed it up b/c at first i didn't have a big enough c clamp to push the piston back in so i decided to use an rachet extension and a hammer to force it in but everytime i do that the front part of the caliper moves as well. i tried that for about 10 times w/o any luck. then decided to go buy a bigger c clamp..it worked. also it seems like the pad is not biting down on all of the rotor like the other side, only about 75% of the rotor. and when i first tried to take the rotor out i forgot that the e brake was on so i got mad and started hammering the old rotor out which didn't work, and when i realized that the e brake was on, i put it back down and took the rotor off and some of the brake shoe spring and cup holding the brake shoes came off but i got it back together..but now when i pull the e brake it's higher than it was before i did this brake job....
Old 05-16-09, 06:03 PM
ucfa4
ucfa4's Avatar
That would only make sense that its tighter bc you have new brakes.
Old 05-18-09, 04:48 PM
SHOLEXMAN
SHOLEXMAN's Avatar
You might have pushed the piston in there crooked which messed the caliper up. Did you put grease on the piston? You're supposed to do that when you do a brake job especially when the pad is nearly gone. The colors are BAD sign I would check that caliper out ASAP! If your going to look at it by your self jack the rear of the car up and see if that wheel does not want to spin or gives you major resistance. If it is replace the caliper. You might have to adjust your parking brake man. If that is sticking on the L/R where everything feel out that parking brake is probably engaging it all the time. So many issues with this car.....
mikhett
RX - 1st Gen (1999-2003)
08-14-18 06:26 PM
SlickNick3
Suspension and Brakes
06-11-10 07:59 PM
New York
06-02-09 06:59 PM
minla007
08-15-06 02:38 PM
indo79
04-09-06 09:26 PM
Quick Reply: new brake rotors gets hot?
