check engine light goes on and off now and again.
Old 06-17-09, 04:40 PM
rogsc400
rogsc400's Avatar
Default check engine light goes on and off now and again.
My check engine light comes on and off.......It comes on when I'm driving the car hard but bout time I try to get the car to autozone to check the codes its off again. Then I wont see it come on again for awhile. I 1st thought it came on cause I put a injen short ram and change my exhaust and deleted my resonators. If my o2 sensors where bad would it cause my check engine light to come on and off every now and again or is it something bigger? The car sits alot. I drive my car maybe twice a week some times less than that. Any ideas
Old 06-17-09, 05:58 PM
StiCk3
StiCk3's Avatar
92 SC400 is OBDI. Autozone can only read OBDII cars so don't go there. Do this instead:
http://www.troublecodes.net/Toyota/
report back here with results. The codes should still be in there even if the check engine light goes on and off.
Old 11-19-09, 06:33 AM
carbophat
carbophat's Avatar
I have the same problem. I can't get anywhere that can check the codes. There has been on instance where I actually go somewhere to check it but as soon as they turn the car off the lights turn off... ugh! so aggrevating!
Old 11-19-09, 07:18 AM
Debonair
iModerate
Debonair's Avatar
And IF the car is a 96+ find a Mechanic that does real diagnostic work and has a real scan tool. They will be able to access both current and history (previous) codes.
Old 12-02-09, 08:14 AM
carbophat
carbophat's Avatar
Okay, so I read over this site, but which of the three am i looking for in a 92 SC400? I really don't want to pay Lexus $100 just to read this thing..
Old 12-02-09, 12:17 PM
StiCk3
StiCk3's Avatar
It's the first image, just get a paper clip, bend it up and jump those two ports. There is a schematic of the ports on the otherside of the cap covering the diagnostic plug.
Ladoo1980
IS - 1st Gen (2001-2005)
04-23-17 10:28 AM
clevercat
RX - 1st Gen (1999-2003)
07-07-09 06:39 AM
melissac
06-30-09 04:50 PM
howiedoit
01-30-02 01:08 PM
Quick Reply: check engine light goes on and off now and again.
