sc400 wheel problem in the rear
Old 06-22-09, 03:00 PM
turboecho
turboecho's Avatar
Default sc400 wheel problem in the rear
hi guys
i am a newbie here and i would appreciate some help. i have a 1993 lexus sc400. the other day after i filled up with gas i turned out of the gas station and my rear end was all over the place (drove about 20 feet). i pulled over and noticed that the rear passenger side wheel was all crooked. so i towed the car home. weird this is when i put the car in reverse the wheel sits back where it normally should the moment i go to drive it forward the wheel becomes crooked.
any suggestions what it might be? bad wheel bearing or axle?
thanks in advance!
bruce
Old 06-22-09, 03:38 PM
xtra
xtra's Avatar
wow , that's a strange one, any way you can maybe take a picture of the crooked wheel?
Left to right movement would be tension arm or traction arm , up and down movement would be rear bolt join or realley bad shocks.
Old 06-22-09, 06:08 PM
ucfa4
ucfa4's Avatar
Its probably a broken lug or two. I wouldnt drive it until you get it fixed.
Old 06-22-09, 07:00 PM
turboecho
turboecho's Avatar
The rears have new KYB-GR2s. I'll try to get a photo of it.
I am used to doing repairs myself. I just was wondering what you guys would think before i go out and order a bunch of parts to fix it.
Lug nuts are ok. I removed the wheel and checked for play. It doesseem to have a little bit of play in the wheel bearing but not enough for me to believe that its bad....
I am just unfamiliar with the SC400... Time to learn i guess...
Old 06-22-09, 07:05 PM
Amini9
Amini9's Avatar
Welcome to CL, where we try to help everyone fix any problem with the SC. If you think something is broken, it probably is broken. If you think about a part that might be bad, it's going to be bad
Mr.NA_T
Mr.NA_T's Avatar
Old 06-22-09, 07:25 PM
DJ420a
DJ420a's Avatar
Bad wheel bearings?
rhunter
07-01-19 01:37 PM
nathantse
10-17-18 03:25 PM
cdvmagic
Maintenance
05-31-08 03:20 PM
sxwk12
09-10-04 08:41 AM
Quick Reply: sc400 wheel problem in the rear
