1 UZ-FE performance upgrade w Temp Sensor replacement?
Old 06-24-09, 07:49 PM
over40driv
over40driv's Avatar
Man 30 min. of plastic removal. Be very careful when unplugging the 2 wire plug to the coil thats over top of the sensor it has a very light clip on the plug and if you squeeze it to hard it will snap.
Old 06-24-09, 07:52 PM
fliptrix
fliptrix's Avatar
Any noticeable difference in the way it idles/drives/runs after installing it?
Old 06-24-09, 08:02 PM
over40driv
over40driv's Avatar
No sealant and there was a fact. copper washer, the antifreeze will want to start weeping out, so just start the new one in right away and torque it down. Mine with 135,000 was pretty corroded.
over40driv
over40driv's Avatar
Wont drive until tommorow.
Old 06-24-09, 09:47 PM
fliptrix
fliptrix's Avatar
I'm probably going to stop by Autozone tomorrow and pick one up and give it a shot. My SC has been perfectly maintained and runs awesome... so we'll see how mine looks and how this turns out I guess... haha.
Old 06-25-09, 01:26 PM
damon
damon's Avatar
Some are warning to be weary of the non oem part.
No idea as to the validity of this.
Old 06-25-09, 05:05 PM
over40driv
over40driv's Avatar
Drove the car today with A.C. on just as the day before, no sluggishness when leaving stop signs. The car felt smoother and more tuned. When the car is in O.D. and you pull down to 1400-1600- RPMs it still has its light miss, must be a diff. issue, Prob. either injector wear, or MAF glitch. I did have the battery unhooked over night to reset ECU, guess we'll have to see how it does long run, so far, the best its ran.
Old 06-26-09, 11:30 AM
damon
damon's Avatar
Over40,
Be very careful trying to service your "MAF"
You actually have a piezoelectric filament, air flow meter (AFM) and it does not like to be sprayed with any solvents!!
This is definitley not a part you ever want to have buy new!
Old 06-26-09, 12:29 PM
sc-driver
sc-driver's Avatar
damon,
are you talking about the hotwire maf sensors when you say piezoelectric filament? Only 96+ sc400's are equipped with these and there is a spray you can buy at almost any auto parts store that is specifically designed to be sprayed on hotwire sensors.
A hotwire maf sensor has a wire heated up to a certain temperature, and depending on the amount of air coming in, the resistance of it changes. Therefore the voltage that can go across changes.
92-95 sc's have a karman maf sensor that has an led that reflects light off a mirror and measures the number of vortexes created by the incoming air. I am not certain if its safe to spray this maf cleaner on these types of sensors but I have seen it done without problems.
Just wanted to clear up any confusion.
Old 06-26-09, 01:01 PM
damon
damon's Avatar
Not sure what year they changed on the LS series.
90-94's model have a Karmann Vortex AFM which utilizes a piezoelectric filament. Several folks (me included) had very negative experiences with the specific MAF cleaner.
Old 06-26-09, 01:18 PM
sc-driver
sc-driver's Avatar
damn that sucks. I used that spray and it worked wonderfully for me. I guess in your case I would've used something like dust-off.
Old 06-26-09, 05:31 PM
over40driv
over40driv's Avatar
Counts the vortexes, that sounds simple enough.
Old 06-26-09, 05:35 PM
over40driv
over40driv's Avatar
Seariously though, if Im keeping my car for another 100,000, and all it needs is a new AFM , whats the best way to go?
Old 06-26-09, 06:33 PM
sc-driver
sc-driver's Avatar
hit up aliga and see if he can get you one for a good deal. Otherwise, like I said, get some dust-off and try that.
Old 06-26-09, 06:54 PM
over40driv
over40driv's Avatar
I cleaned the MAF with cleaner a year or so ago, didnt seem to make any diff. How would you know if the MAF was the prob. with no CEL?
Quick Reply: 1 UZ-FE performance upgrade w Temp Sensor replacement?
