1 UZ-FE performance upgrade w Temp Sensor replacement?
Old 10-05-11, 06:48 PM
  #76
SkulCracka
SkulCracka's Avatar
the radiator sensor is to control your fans. the two sensors near left side front of engine are for the temp for the ecu and the cluster gage. factory one they are speaking of in this thread is the large plug with green top. smaller one behind that is the one with one wire to the temp gage in your instrument cluster.
i have a bad o2 that i will be replacing this weekend. have them right here "denso's". only getting code 21 for the main left one. but will replace both. thinking i will also replace this sensor spoken of in this thread along with the 2 main o2's.
Old 10-07-11, 04:43 AM
  #77
G'WAY
G'WAY's Avatar
my 1992 sc 300 shuts down after driven 5-6 miles; won't re-start. I wait 3 or more hours; car re-starts. I drive again; the cycle begains again
Old 10-07-11, 04:50 AM
  #78
G'WAY
G'WAY's Avatar
Default sc 300 1992
I drive 5-6 miles; car shuts down, won't re-start. I wait 3 or more hours, car starts, i drive 5-6 miles car shuts. I replace the fuel filter; same thing. I thinking of re-placing the crankshaft sensor. HELP !
Old 10-07-11, 07:34 AM
  #79
xspsi6
xspsi6's Avatar
Fuel pump ecu most likely^^
Old 07-16-13, 12:50 PM
  #80
1lowsc400
1lowsc400's Avatar
Very interesting points I must try this this weekend
Old 06-18-14, 12:01 AM
  #81
t2d2
t2d2's Avatar
I haven't seen it mentioned; has anyone tried simply cleaning their OEM sensor? Corroded copper shouldn't be that tough to clean up, but I don't know how delicate the sensor itself is. If the quality of the aftermarket sensors is in question, as it seems to be, salvaging the OEM one would be worth a shot.
Originally Posted by sc-driver
So I just did this today. Bought the OEM replacement from autozone. It wasn't too bad getting it out. Putting everything back together was painful.
My car is from 1996 and has about 122K miles on it. Garage-kept most of its life too. So after installing it, all I can say is wow. There is such an improvement in the entire rpm range. I can feel the biggest difference at low and mid rpm. The high end seems about the same.
I highly suggest everyone to at least check the condition of theirs. I am very happy with this.
Old 07-08-14, 10:37 PM
  #82
oldManTan
oldManTan's Avatar
OEM toyota sensors are 40 bucks shipped on ebay. i'll be ordering one tomorrow and change it out. my cars got a quarter million miles almost so why the hell not. and my 0-60 time is 8.5 seconds. should be 7 according to lexus
Old 07-08-14, 11:40 PM
  #83
t2d2
t2d2's Avatar
I ended up finding other threads saying it's perfectly fine to just clean the sensor. However, when I took mine out, it had already been cleaned quite recently. Worse, the sensor was all busted up from the monkey that wrenched on it, with a broken plastic base, broken connector clip, and bare wire. So, I bought a new one, after all, and ordered a new pigtail connector which I haven't installed yet. I didn't notice any changes with replacing just the sensor.
Old 07-09-14, 11:42 AM
  #84
Sc400NL
Sc400NL's Avatar
same here , very clean but replaced it anyway
didn't notice any difference at all
Old 07-09-14, 03:28 PM
  #85
oldManTan
oldManTan's Avatar
how many miles do both of your cars have? i ordered my sensor today on ebay for 42 bucks because at the dealerships they were 90 bucks!
Old 07-09-14, 05:09 PM
  #86
t2d2
t2d2's Avatar
Mine's got 189,000 miles. I went with a Beck Arnley sensor (#158-0421), which you can get for $15 or less. It's probably off the same assembly line as the OEM part.
Old 07-09-14, 11:41 PM
  #87
oldManTan
oldManTan's Avatar
OEM sensor is shipped. i'll be posting up results when i install it and run some 0-60 runs.
Old 07-10-14, 12:46 PM
  #88
Sc400NL
Sc400NL's Avatar
150K KM or 93K miles
the sensor itself looked very clean but i could see on the brittle plastic that it must have been in there a long time , guess factory
cheap fix for around 18 USD here in Europe , just go for it Oldmantan its a preventing tune up you know it won;t go bad for years to come
Old 07-13-14, 01:29 PM
  #89
oldManTan
oldManTan's Avatar
changed mine today, about to go to work and see how it feels. reset the ECU as well. the old sensor looked awful
Attached Thumbnails 1 UZ-FE performance upgrade w Temp Sensor replacement?-dsc_0183.jpg   1 UZ-FE performance upgrade w Temp Sensor replacement?-dsc_0184.jpg
Old 10-23-17, 11:19 PM
  #90
DrAtomica
DrAtomica's Avatar
Bumping up old thread to see if it actually did make a difference or not, it's an interesting theory and perhaps if someone measured their 0-60 times on before and after it can help to prove it.
Quick Reply: 1 UZ-FE performance upgrade w Temp Sensor replacement?
