1 UZ-FE performance upgrade w Temp Sensor replacement?
Old 06-22-09, 10:25 PM
damon
damon's Avatar
Default 1 UZ-FE performance upgrade w Temp Sensor replacement?
Just wondered if anyone in the SC400 clan has noticed this same phenomenon as many of us LS guys??
Not any real rear wheel HP to speak of ofcourse but a marked improvement in driveability!
https://www.clublexus.com/forums/ls4...ange-pics.html
Part # 89422-20010 Sensor
Old 06-23-09, 01:00 AM
Ryeno
Banned
Ryeno's Avatar
i have heard of people changing out that sensor back in my camry days. Hear it does make a difference.
Old 06-23-09, 09:52 AM
damon
damon's Avatar
Restoration of performance would be a better assesment.
Old 06-23-09, 11:56 AM
HellFish
HellFish's Avatar
i saw that the ECU was reset. i wonder if this is where most of the restoration of performance was gained?
Old 06-23-09, 01:48 PM
sc-driver
sc-driver's Avatar
When I found mine, it was already loose from the connector. Turns out, it failed or moisture permeated inside, and was VERY corroded. After the install, I took her for a quick spin. I did not remove the ECU fuse during the removal/install because I wanted to see the results without any benefit of the ECU reboot.
Results were smoother idle and powerband. Quick acceleration. I am now a believer. Thank you CL, jasonburt and Zoraone.
Seems like this is really legit.
Old 06-23-09, 03:00 PM
QwkSC
QwkSC's Avatar
So is the ECU retarding the timing because it thinks the engine is running hotter with the old temp sensor?
Old 06-23-09, 03:23 PM
fliptrix
fliptrix's Avatar
Sounds interesting... anyone wanna be the first to try this out? haha
Old 06-23-09, 05:01 PM
OneSickSC
OneSickSC's Avatar
it seems to be tru...someone should change it
Old 06-23-09, 05:24 PM
HellFish
HellFish's Avatar
ill test it. i dont have anything better to do tomorrow. haha.
the ECU will retard the timing because of knocking with ****e gas. resetting the ECU will rid that and give you a little boost in performance.
Old 06-23-09, 07:54 PM
over40driv
over40driv's Avatar
If anyone has the COOLANT TEMP. SENSOR #for the 95 SC400 I would appreciate it. Sounds promising to get rid of cold rough running prob.
Old 06-24-09, 08:00 AM
damon
damon's Avatar
Fairly certain the part # I left is correct for your 95.
I used this same part # on 90, 94 & 96 LS 400's.
That is a toyota oem part #. There is some debate on the LS Forum as to the performance of the cheaper aftermarket sensors.
Old 06-24-09, 02:39 PM
over40driv
over40driv's Avatar
I bought a BWD , coolant temp. sensor, made in the USA, from Advance today, $29.95. The parts guy told me over the phone it was a Borg Warner, but it dosent say that anywhere on the box. It did not come with a gasket, and the parts guy informed me that none of the BWD sensors do. It also says its a Z series. Should we use any sensor safe silicone or teflon tape to avoid leaks? I havent taken the old one out yet to see how the fact. sealed it. Good catch on needing a deep well socket, as I keep some tools at a diff. location 19mm... The part # was a wt653z the invoice refers to the part as a radiator switch, but of course I told the guy i wanted a coolant temp. sensor. BTW, with my A.C. on today I noticed a lot of sluggishness pulling away from stop signs, and a jerking in O.D. at 1400- 1600 RPMs. Hope this part helps.
Old 06-24-09, 05:27 PM
sc-driver
sc-driver's Avatar
do it and let us know what happens
Old 06-24-09, 05:31 PM
over40driv
over40driv's Avatar
My bad DAMON I didnt catch that part # at the bottom of your thread. Got to let her get cooled down to swap the part out.
Old 06-24-09, 05:56 PM
fliptrix
fliptrix's Avatar
lets us know how it turns out! pretty interested in how much change there will be for the SC.
Quick Reply: 1 UZ-FE performance upgrade w Temp Sensor replacement?
