Alternator not charging?
Old 07-13-09, 01:32 AM
visi0n
visi0n's Avatar
Default Alternator not charging?
bought a new alternator...applied volt meter to battery. volt meter reads 12.5 volts. rev the engine up, volt meter still reads 12.5 volts.
bought alternator to kragen to be tested, their test shows that the alternator is outputing the required 13-14 volts it should be putting out.
daily driving my car is killing the battery and if i shut my car off the battery doesn't have enough juice to start the car.
what could be the issue? i already brought my battery to kragen and they charged it and said its perfectly fine. they also load tested the battery.
Old 07-13-09, 10:11 AM
SC40095
SC40095's Avatar
I would say to check the harness that goes into the alternator. Had the same problem and found out that I had two wires going into the harness when it was supposed to be 3. They are very small gauge wires and it looks like it don't take much to rip one out. If it is that then there's a place online where you can order a new plug with better wires.
Old 07-13-09, 11:25 AM
visi0n
visi0n's Avatar
got a link?
Old 07-13-09, 11:37 AM
SH_JZZ30
SH_JZZ30's Avatar
If the harness is fine then you can check the voltage on the postive terminal of the alternator while the engine is off. It should read the same as the battery. That way you can know there's no breaks in the cable.
Old 07-13-09, 04:38 PM
7sins
7sins's Avatar
I had this problem and it was the big 80amp or 120amp (can't remember how big it was) fuse. The one under the hood that is screwed in.
Sorry for the lame description!! I just have trouble remembering small stuff like that. If I'm right I think it was white too
Old 07-13-09, 07:17 PM
visi0n
visi0n's Avatar
what about it? it was blown?
Old 07-14-09, 10:27 AM
SC40095
SC40095's Avatar
I'll get you a link when I get home.
Old 07-27-09, 02:55 AM
visi0n
visi0n's Avatar
find the link yet?
Old 07-27-09, 06:08 AM
SHOLEXMAN
SHOLEXMAN's Avatar
Either you have a cut in the harness or the power or ground points could have corrsion on them. The 150 mega amp fuse it is right next to the 2 60 mega amp fuses. Its in the engine bay on the drivers side. See if the fuse burned up. There are screws holding it in place your going to have to take the screws holding the fuse panel together off the car. Then you take the box apart and get to the screws. Search for it man there are over 20 links for charging system issues.
Old 03-13-18, 09:34 AM
Kodiak303
Kodiak303's Avatar
So was it the mega amp fuse?
i have the same alternator issue.
gregs69rs
05-18-20 11:41 AM
TriniLex
ES - 5th Gen (2007-2012)
25
12-21-15 02:17 PM
STRONG SC
10-10-05 12:58 PM
SLVRGS
GS - 1st Gen (1993-1997)
02-03-04 11:54 AM
Quick Reply: Alternator not charging?
