Start Up Squeak
Old 07-24-09, 09:51 AM
ES BL155
ES BL155's Avatar
Default Start Up Squeak
My moms rx300 has 100k on it and whenever we start it when the car is cold it squeaks. i thought it would've been a belt. we got the tb/wp and all the belts changed out with the 100k service but it still squeaks. any ideas?
Old 07-24-09, 09:56 AM
thomas1
thomas1's Avatar
Were they OEM belts? If so maybe still too loose....
Old 07-24-09, 10:15 AM
ES BL155
ES BL155's Avatar
the oem belts squeaked. belts were changed at 100k but still squeaks.
Old 07-24-09, 11:58 AM
bob2200
bob2200's Avatar
It still is likely one or both of the two accessory belts (i.e., not the timing belt).
Old 07-24-09, 01:56 PM
code58
code58's Avatar
Have to ask 2 questions ES. Those that know me know that I don't ask questions without a specific reason. #1 is what were the replacement belts (p/s & a/c, alt.), were they OEM Toyota or aftermarket and the second question is were the idler & tensioner pulleys and the tensioner replaced? Third question, (sorry), were OEM TB & W/P used? When I see the answers to these, I may have more input.
Old 07-24-09, 01:58 PM
carguy07
carguy07's Avatar
My money says belts too. Right after I got mine it started making a chirping noise. I was almost positive it was something along the lines of a bearing in the alternator. The belt was OE, looked tight and did not look worn. I took it in to the dealer and they listened to it. Within seconds they said it was a belt. A few hours later I pick it up and it never made the sound again. They hooked me up and did them free under CPO.
Old 07-24-09, 04:29 PM
sktn77a
sktn77a's Avatar
Spray some water on the visible belts. If it's the belts, it will stop squeaking temporarily. If it doesn't stop squeaking, it's you idler/tensioner.
Old 07-24-09, 08:28 PM
JohnLX300
JohnLX300's Avatar
I had some of the same issues....I used Prestone belt dressing as a temporary band aid, then I had the everything changed with the t-belt. Now my car runs like new and I have about 90,450 miles on it.
rposso
Performance
09-07-17 08:18 PM
Elless400
06-21-17 08:30 AM
fastegg
15
02-29-16 04:13 PM
moat
25
02-15-12 06:29 PM
jayr0422
09-02-09 05:29 PM
Quick Reply: Start Up Squeak
