please help me how to remove the rear wiper blade.
Old 07-31-09, 07:50 PM
ohiois350
ohiois350's Avatar
Default please help me how to remove the rear wiper blade.
like the title said, please someone help me how to remove the rear wiper blade on rx330 thanks
Old 07-31-09, 10:13 PM
KeysRx300
KeysRx300's Avatar
Default Rear Wiper
OhioIS350
Welcome to Clublexus. Just a couple of tips.
Search Google prior to posting any questions. If you have no luck. Use the search function on Clublexus. Every question you could possibly think of asking. Ever. Has already been answered.
On the base of the wiper blade near the glass. The arm assembly will only lift up an inch or so. There is a small plastic cover on the base. Pull on both of the sides at one time. And it will lift off. Once its off. The arm will go up like the ones in the front.
Old 08-01-09, 02:21 AM
tromly
tromly's Avatar
Originally Posted by KeysRx300
OhioIS350
Your advice is great, wish Lexus had put it in the owner's manual, also I found out the auto parts stores don't stock the rear blade, only available at Lexus.
Old 08-01-09, 06:43 AM
kiwi
kiwi's Avatar
dont buy wiper blades at an autoparts store, waste of money, go to lexus and get the refill for 7 bucks
Old 08-01-09, 11:02 AM
ohiois350
ohiois350's Avatar
OhioIS350
thanks kiwi, but you mean by pulling 2 pcs plastic on the blade? any pics so I can figure out what you are talking about. hope you can help me clearly on this, thanks
Old 08-01-09, 09:35 PM
biff44
biff44's Avatar
If you are talking about just sliding in a new blade, and reusing the metal arm assembly/holder, then you just flex the blade outward in the middle of its length. This "shortens" the blade length, and you can then wiggle one end of the blade free. Then you just slide it out to one side.
Old 08-02-09, 11:59 AM
ohiois350
ohiois350's Avatar
I got it! it very easy, just pull the base wiper blade cover where the base of the the blade crew down to the window, after I pull that cover off, I was able to lift the blade up higher and remove the wiper blade.
Grumpa72
06-12-22 05:52 PM
spacecraft
05-31-13 05:51 AM
rfcbuf
12-29-12 02:28 PM
jfarber
05-27-08 07:21 AM
Capirato
GX - 1st Gen (2004-2009)
12
12-10-07 10:35 AM
Quick Reply: please help me how to remove the rear wiper blade.
