92 sc300 steering wheel slop
Old 11-29-09, 03:56 PM
92sc300nj
92sc300nj's Avatar
Default 92 sc300 steering wheel slop
ok so i have excesssive steering wheel slop on my 92 sc300.. theres no sounds or anything being made. the lower control arms. tie rods and shocks are all good. im starting to believe its the steering column or the power steering rack.. but my problem is when going around corners i feel the steering wheel like fight me really bad and im constantly correcting it.. sometimes the steering wheel is straight when the wheels are straight and sometimes its kinda at a 3 oclock kinda spot when the wheels are straight i cant figure out what the problem is..
does anyone have any experience with this and if so would you happen to know what it might be? any help or ways to test to see exactly whats wrong would be much appreciated.
ben
Old 11-30-09, 07:32 PM
JamaicanSC
JamaicanSC's Avatar
check your steering rack bushings, mine did the same thing until one of them fell out on me.
Old 12-11-09, 02:40 PM
FutureSC
FutureSC's Avatar
Yep, steering rack bushings for sure. By the way you're describing it, the rubber bushings have probably already fallen out. Definitely change em out.
Old 12-13-09, 09:31 AM
dwebb99
dwebb99's Avatar
There is a good DIY on this forum on changing them out with after market ones. Worth every penny!!! Great upgrade!!!
Old 12-14-09, 01:01 PM
slappy96
slappy96's Avatar
92 SC300
Agree with either rack bushings or steering rack itself. I will say that have new Supra LCA's/Bilstein HD/Supra springs/new oem supra sway/ new oem endlinks and a good alignment....still with too much slop. I have definately narrowed it down to the rack itself, but I would change the rack bushings prior to replacing the rack itself.
MIGS
Performance & Maintenance
12
11-14-10 06:25 PM
cspradlin
Suspension and Brakes
07-16-09 12:58 AM
ghd8989
02-06-07 09:15 PM
neurocity
11-18-06 10:28 PM
Quick Reply: 92 sc300 steering wheel slop
