95 front bumper on 94 SC400
Old 05-12-02, 05:25 AM
JT51
JT51's Avatar
Default 95 front bumper on 94 SC400
I don't like the look of 97+ front bumper on the SC as much as the closed in front on 92 to 96. What I do like is the fog lamps. Will a 95 bumper bolt on to a 94, and what will the wiring for the fog lamps entail.
Old 05-12-02, 09:07 AM
SupraCoup3
SupraCoup3's Avatar
your question is very confusing... could you reword it?
It appears that you want the fog lamps, but you don't like the look of the 97+ front end. (Some people don't like that little grill I guess) but anyhow.
If you want the fog lamps, people on this board have wired the turn signal lights to come on with the headlights. If you want the fog-lights, any stereo shop should be able to make that little change for you.
Old 05-12-02, 12:53 PM
JT51
JT51's Avatar
Basically, I do not like the kit look or the 97+ front bumper look as much as the closed in front , don't know how else to say it, of the 1992-96 SCs. I like where the fog lamps are on the 95 and 96 and I do not care for my cornering lights, to me they are pretty much useless. What I was thinking, could I take the front bumper assembly of a 1995 or 1996, with fog lights, and install it on a 1994 SC.
Old 05-12-02, 03:39 PM
SupraCoup3
SupraCoup3's Avatar
the entire front bumper cover is one peice. You can't get the lower part w/out the upper "open" grill. Unless you want to spend $$$$ on getting a custom application.
I may be wrong, but up until 97 the lower lights on a SC were connering lights. Swapping up to a 95/96 won't do anything for you.
1992-1996 (Basically the same, a few cosmetic changes & what not)
1997-2001 (New Front End w/ grill & fogs, also has side skirts & different tail lights)
(1992-1994 has one style tail lights, 1995&96 has another)
Old 05-12-02, 03:44 PM
lex400sc
lex400sc's Avatar
From 1992-1994, the lower lights were 15w cornering lights. In 1995 and on, they used 55w foglights. You can just buy the 95-96 foglights from the dealership and remove your cornering light housings. You will have to splice in an H3 plug. If you're interested, Steve Ganz at Carson Toyota will most likely have the best pricing on them. 1-800-90-TOYOTA.
Old 05-12-02, 03:55 PM
SupraCoup3
SupraCoup3's Avatar
Ahh, so they did switch them... but as I thought, it's simple electrical work, and swapping the bumper is like killing a fly w/ a 1/4lb of Composition 4... overkill
Old 05-12-02, 04:02 PM
lex400sc
lex400sc's Avatar
Oops, forgot to mention, once you swap the foglight housings, you'll still need to set in an automotive relay to turn them on with the parking lights. Otherwise you just have really bright cornering lights.
Old 05-12-02, 05:19 PM
JT51
JT51's Avatar
Thanks
Old 09-07-02, 05:54 AM
JT51
JT51's Avatar
Seeing a few other posts on the subject, I see that I can not put stock 95 or 96 fog lights in my 94 grille, and add a relay, because they will not fit properly, is that correct? I will need to change my front bumper with new stock fogs and add a relay, as I first suspected?
Old 09-07-02, 02:34 PM
mjr24
mjr24's Avatar
Correct...95-96 fogs will not fit in the 92-94 bumper no matter what you do. You can only have 95 fogs if you have the 95-96 bumper. So if you want the fogs...you need to get the bumper too.
Old 09-07-02, 04:07 PM
Lex Luthor
Lex Luthor's Avatar
Yup, you need the bumper with the lamps.
Old 09-08-02, 12:31 AM
pcmw
pcmw's Avatar
I tried this...no go.
The 95-96 fog lights are double the depth and have a different curve on the outsides.
Can I make them fit....YES....will they stay there and look decent... NOPE.
What happens is that the light goes in...but sticks out flush with the bumper instead of sitting inside the hole. It also causes a stress on the hole. I didn't like the look. Also, after the cutting and shoving, the foglights will aim about 10degrees off to the sides because of the hack job.
The new bumper is the only way to do it. $500+paint is what I found out including the fogs.
MW
Old 09-08-02, 01:37 AM
Dimcorner
Dimcorner's Avatar
So basically...
If I want to convert the 92 front to the 97+ front i would need the following...
Front bumper skin
Fog Lights
Relay
Foam bumper behind the skin
Am I missing anything?
Also, if I get a Bomex 97 kit, i am assuming i just need to buy the fog lights right?
Old 09-08-02, 01:47 AM
ChrisSC300
ChrisSC300's Avatar
Ask yourself this. Why do you want the fog lamps? Just for looks or do you need those extra 2 lights that bad for visibility. Doing a simple relay with your cornering lights would do the trick. It would look almost the same and I am sure lighting on the road wouldent be much different. Why do somethin that would cost you close to $600 when your could just rewire them and have almost the exact same look for nearly nothing.
Old 09-08-02, 01:49 AM
AutoCoutureSC
AutoCoutureSC's Avatar
Post
very true chris.... very true...
Quick Reply: 95 front bumper on 94 SC400
