How to change the Navigation DVD
Old 01-21-10, 08:23 PM
barista
barista's Avatar
Post How to change the Navigation DVD
This question is for 2007 RX 350.
I have the navigation DVD but not sure how to change it. Does it stay permanently in the car. If so how do I eject the old one and insert the new one. Can somebody please share the steps?
Old 01-21-10, 09:05 PM
barista
barista's Avatar
Ok. I found the instructions here: http://www.sewellpartsonline.com/imp...ationGuide.pdf
It says
Disengage the 2 clips and 2 guides, and remove
the front console box cover.
I don't know where that is. Could anybody here help me understand the location and how exaclty to reach the nav computer?
Old 01-22-10, 01:19 AM
KeysRx300
KeysRx300's Avatar
Default Dvd
Barista
Welcome to Clublexus. Just a couple of tips.
Search Google prior to posting any questions. If you have no luck. Check the owners manual. If that doesnt have it. Use the search function on Clublexus.
Every question you could possibly think of asking. Ever. Has already been answered. This way you wont have to wait.
https://www.clublexus.com/forums/rx-...vd-update.html
1) Remove rear tool tray( NAV DVD player is underneath)
a)fold down rear seats
b)find velcro tabs on each side of rear tray cover where it meets back seats
c)lift velcro tabs
d)slide fingers gently along edge where rear cover meets rear seats to release 5 plastic push pins.
e)Use 12mm socket to remove the 2 now visible hinge bolts
f)remove tool tray cover
g) remove tool tray, There are 2 black push pin on both sides that pry up easily. NAV DVD player should now be visible on passenger side
2) Put ignition in ACC position
3) If there is a dust cover on unit remove it. Mine did not have this. Some do.
4) There should be a "slide type button" on your left of the unit. Slide this button to your left(facing unit). DVD should eject
5) Insert new DVD
6) Slide button back to original position
7) allow NAV to update before turning off ignition( check NAV Screen)
8) Reassemble in reverse order.
Old 10-06-12, 06:47 AM
therods
therods's Avatar
I have a 2007 is250. Can you post navigation cd replacement?
Old 10-06-12, 08:13 AM
Rainbird
Rainbird's Avatar
Here is a acrobat document that shows the location and procedure to change out the DVD on most all Lexus vehicles:
File Type: pdf
Old 10-06-12, 08:28 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
Please check the 2nd gen IS forums - this section is for the RX (although you got your answer posted anyway )
Old 10-06-12, 08:51 AM
therods
therods's Avatar
Thanks!!!! Your reply and instructions are EXACTLY what I needed!!!!!
Old 09-25-15, 01:54 PM
akop
akop's Avatar
Cool
Hi....I don't know if you still looking for answer....but check this simple video:
degilmer
04-09-19 12:48 PM
KIMBERLY06
11-06-14 05:39 AM
Grobby1
03-06-10 05:22 AM
ramy
01-18-08 05:54 PM
Quick Reply: How to change the Navigation DVD
