Anyone have a power steering diagram for a '96 es300?
Old 02-15-10, 08:06 PM
mtnman82
mtnman82's Avatar
Default Anyone have a power steering diagram for a '96 es300?
Please, please, pretty please???
New owner here and I have a very bad leak, I'm pretty sure is coming from a hose. Been to a couple parts places but no diagrams and it's a bit confusing...
Do they really power the radiator fan with the power steering fluid?!? WTF???
A good diagram or drawing with all the hoses/pump/rack would be indispensible, if anyone has one or a link to one. Something with part #'s would be awesome(!).
Also, are there any links to a service manual for a '96 es300?
Old 02-15-10, 08:34 PM
ASG14
ASG14's Avatar
Um, a 94 and I think 95 poweres the fan, 96 does not. So what year is your car?
Old 02-15-10, 11:02 PM
mtnman82
mtnman82's Avatar
It's a '96. I can see a hose coming & going from the radiator fan assy (looks like from the drivers side thru the fan and then out towards the passenger side?), and it looks like the power steering filter up top behind the radiator(?). I'd be happy to snap a pic and post it it helps..
Old 02-15-10, 11:39 PM
ASG14
ASG14's Avatar
It's not a 96 then. Take a pic of your VIN sticker on your car or tell me what month/year is says.
Old 02-16-10, 04:51 AM
MikeLex
MikeLex's Avatar
Yes, and the fluid pressure is electronically controlled by the cooling fan ECU.
Attached are diagrams showing the pump and the rack. Check the hoses, but it's likely you will have to reseal the pump.
File Type: pdf
File Type: pdf
Old 02-16-10, 10:40 AM
llcoolpass
llcoolpass's Avatar
search for 1993 FSM and 1997 FSM. pick the one most similar to yours .... which like asg, i thought yours was electronic fans not hydraulic fans.... let me see here ...
edit: going by ******* you do have hyd fan. then use the '93 FSM for a diagram
edit2: here is the picture [and youwill see more related pictures] from my photobucket
http://s69.photobucket.com/albums/i7...tempsensor.jpg
Old 02-16-10, 03:36 PM
ASG14
ASG14's Avatar
Ok, so I wa slookign up pics and saw one '96 with the hydrolic fan, yet in some junkyards, I know I have seen a couple without......
Toyota, we leave you wondering........lol. Damned if I know.....
Old 02-16-10, 04:37 PM
mtnman82
mtnman82's Avatar
The sticker says it was built in 01/96, so maybe they changed during the '96 model year...
So they control the fluid to propel the fan electronically? Why not just an electric fan wonder?
Well, it is what it is. But it sure would be neat to see a diagram/drawing of the power steering fluid system. It would help immensly in determining which hose(s) I need.
Old 02-16-10, 05:17 PM
ASG14
ASG14's Avatar
Use the '94 Camry one: http://www.turboninjas.com/camry/
I know a guy personally that had a '91 ES300, and another guy with a late '96 ES300 with '97-'01 sway bar bushings/brackets on it from the factory.....figure those 2 out.
Old 02-16-10, 07:05 PM
mtnman82
mtnman82's Avatar
MikeLex - thanks for the pump & rack diagrams!
llcoolpass - thank you immensly for the link to your drawings! That helps make sense of things a bunch (i.e. the 2 PS fluid circuits sharing the same pump and reservoir).
ASG14 - thank you immensly too for the link to the manuals!
Old 02-16-10, 07:19 PM
ASG14
ASG14's Avatar
BTW, if you have any specific Q's after looking it all over, PM me and I'll hand them over to one of the mechanics at my dealer to hopefully answer it.
Old 02-16-10, 11:01 PM
llcoolpass
llcoolpass's Avatar
they used hydraulic because of NVH. it's superior. It's also rare. there's even a filter for the fluid. well designed.
Old 02-18-10, 10:36 AM
mtnman82
mtnman82's Avatar
Thanks guys! BTW, what is NVH?
Old 02-19-10, 09:21 AM
mtnman82
mtnman82's Avatar
Well, it's a little confusing going to a parts counter and asking about the power steering hoses becasue there are a few of them and no diagrams or pictures to help. The links above help tremendously, but I still had to trace hoses to figure everything out. I wound up drawing a diagram of the power steering fluid hoses with both circuits (power steering and cooling fan) and thought I'd share with the forum. Hopefully it'll make someone's life a little easier in the future. The single line is hard tubing and the double lined sections are rubber hose.
Attached Thumbnails Anyone have a power steering diagram for a '96 es300?-scan0010.jpg
Old 02-19-10, 10:24 AM
llcoolpass
llcoolpass's Avatar
you can't buy those hoses at any part store, they are dealer only. although you can improvise with straight hose and highpressure-withstanding elbows - just need the inner diameter in that case and a nearby lowes home improvement place haha. some of the hose though is special and really you have to get it at the dealer.
your picture is accurate.
Quick Reply: Anyone have a power steering diagram for a '96 es300?
