50,000 mile service
Old 03-28-10, 06:59 AM
igorxx
igorxx's Avatar
Default 50,000 mile service
I see owners writing about timing chain adjustments on their car. I don't see anything in my service manual about doing that. All i see is change oil, filters, rotate tires, and check nuts and bolts.
Old 03-28-10, 08:56 AM
iolmaster
iolmaster's Avatar
No timing chain in an SC430. Timing belt. Change at about 90-100 thousand miles.
Old 03-28-10, 09:02 AM
scdroptop
scdroptop's Avatar
Or by years...either/or
Most 02 owners are considering or have done it regardless of miles. 8 years is typically 96k for average mileage.
Old 03-28-10, 11:27 AM
TooCoolSC
TooCoolSC's Avatar
I've always heard that Lexus recommends every 6 years OR 90,000 miles.
Old 03-28-10, 12:13 PM
scdroptop
scdroptop's Avatar
From www.lexus.com...
Recommendation is to change at 90k miles or 108 months (nine years)...here is the list
o Replace engine oil and oil filter
o Inspect nuts and bolts on chassis2
o Measure brake pad thickness and rotor runout
o Replace air conditioner filter
o Replace brake fluid
o Replace engine air filter
o Replace timing belt
o Re-torque drive shaft flange bolts
o Rotate tires
o Road-test vehicle
o Inspect the following:
____Ball joints and dust covers
____Body ____
____Brake lines and hoses ____
____Differential oil
____Drive belts
____Drive shaft boots
____Engine coolant3
____Exhaust pipes and mountings
90,000 Miles or 108 Months
____Fuel lines and connections, fuel
tank band and fuel tank vapor
vent system hoses
____Fuel tank cap gasket
____Rack and pinion assembly
____Steering linkage and boots
____Transmission fluid
Old 03-28-10, 12:54 PM
TooCoolSC
TooCoolSC's Avatar
108 months (9 years)? So where did the six year thing come from? We've been talking about having '02 & '03 timing belts replaced for ages. But that's not accurate, according to this.
Old 03-28-10, 01:47 PM
Harold57
Harold57's Avatar
I was lead to believe that it was 6 years also by my Lexus service advisor and another shop also. I just checked my owner's manual and it says that the information is in the owner's supplement manual (arggg!), which didn't come with my car, of course.
Old 03-28-10, 01:56 PM
Harold57
Harold57's Avatar
Found it. On page 104 of the Supplement Maintenance Manual, it states 90,000 miles or 72 months. Of course, this is for a 2002 SC430. Maybe your information SCDROPTOP was for a different model year. Here is the Lexus link for that manual.
https://secure.drivers.lexus.com/lex...html&locale=en
Old 03-28-10, 03:01 PM
TooCoolSC
TooCoolSC's Avatar
That's a great link, Harold. Thanks. And just as you suspected, it looks like what Lexus recommends as far as the timing belt does, in fact, depend on the year of your car.
Here's the manual for a 2007 SC 430, and it says the timing belt should be at 108 months, or 90k miles. Notice, that there's not an interval of "72 months or 90,000 miles" in this manual. Strange.....
http://secure.drivers.lexus.com/lexu...html&locale=en
This is where you can find all the manuals for any car, as well as videos and other interesting things.
http://secure.drivers.lexus.com/lexu...ources/home.do
Old 03-28-10, 04:09 PM
Yes
Yes's Avatar
it's the same engine. and from what i can tell, the same part number. so it's a little odd they would change the recommendation.
Old 03-28-10, 04:17 PM
Harold57
Harold57's Avatar
Perhaps they've accumulated enough statistical information to be able to state that it will last longer now (& didn't bother to update the older documentation) or determined that the older parts just are harder on the belts.
scarru
08-14-20 10:32 PM
mdawg630
02-15-09 08:05 AM
Kharizma
10-26-05 11:07 AM
LEXISM
12-28-03 03:08 AM
Quick Reply: 50,000 mile service
