04-06 Sealed Transmission fluid change interval? (The Mother thread)
Old 05-11-14, 07:12 PM
  #181
sorka
sorka's Avatar
Originally Posted by BMW7_LS430
Today I drove the car after yesterday's ATF fluid change.
Car drove nice but as usual.
I didn't have any issues to start with so I guess it is the same for now but I feel that I am on my path to avoid potential future issues.
By the time people get shifting issues transmission is already damaged.
By the time people discover thick and burnt fluid it is too late to refresh. Now they have to wait for eventual demise of their transmission.
Was you're fluid thick? If anything it should have lost viscosity and been even thinner than new fluid. ATF WS is already a very low viscosity fluid and because of that it has to have better chemical protection than is typical in ATF fluids.
Did you're fluid smell burnt? ATF can get quite dark without actually being burned. You saw how dark mine was and it is a practically new transmission with only 25K on the car's odometer. I'm not worried about mine but that's because it shifts perfectly without any issues and it has so few miles on it. There's nothing that really could've gone wrong in such few miles. I'm glad that I changed it when I did rather than just assuming it would last the life of the car. I'm pretty sure that 6 speed sealed Toyota transmissions with ATF WS would look just like mine after 7 years with only 25K miles.
My fluid had the same viscosity and did not smell different than the new fluid but it was very very dark.
Old 05-11-14, 08:00 PM
  #182
BMW7_LS430
BMW7_LS430's Avatar
Drained fluid wasn't thick. When it was draining it didn;t look as bad. I could still see a tint of red.
I forgot to smell is closely but I didn't smell anything from a distance.
I had ATF change at 30K on another "sealed" transmission and it failed at 45K & 8 years. That tranny was known to have problems as opposed to LS430 transmission that is known to be bullet proof but I am not taking any chances.
Old 05-12-14, 04:15 AM
  #183
Bob04
Bob04's Avatar
Finally did drain and refill today. yeah.
Drove car on the ramps.
Jacked up the rear and supported by jack stands.
First checked ATF from overflow plug. It was full and dripped a little. Didn't look bad at first.
Opened up drain plug. 1 qt 24 oz came out.
Lowered the rear and got some extra out. Total 1 qt 30 oz came out. Maybe another 1 oz was stuck to the pan.
Jacked up rear again.
Put the drain plug back on.
I had bought 2 Fram sure drain valves, one for oil and one for the transmission overflow plug, but unfortunately transmission bolts are smaller than oil drain.
I made my own contraption with a funnel, 3/8" tube, and another smaller tube. Smaller tube fit perfectly in the overflow plug.
I fed ATF from funnel as if transmission was a patient. lol. Gravity did it's trick.
I fed 2 qts and started the engine. .Tubing was still attached to the overflow plug.
Went through the gears. Removed the tubing. Got some overflow.Connected tubing again and fed some more ATF. Checked the transmission temperature with hands only. (Body temperature is about 98 degrees. You need transmission between 115 and 130 degrees).
Went through the gears one more time.
Removed the tube and let excess drip out.
Put the overflow plug back on.
Took pictures of new and old fluid. It is not only the bad color but I could see dirt as I was pouring it.
.By the way I was able to locate the cover on the fill plug. It was hard to get driver in there and I didn't have right size wrench.. Next time I am going to open it and see if I can attach a fill tube.
Thanks for taking the time to take pics and post. Very interesting.
Old 05-12-14, 04:31 AM
  #184
Pamperme
Pamperme's Avatar
So as it stands now, there have been no reported LS 430 transmission failures after fluid changes just as there have been no reported failures from those who have never had their fluid change. I had 196,000 miles on my 04, never changed the fluid, and it drove just fine. So the score as it stands is:
Failure with fluid change: 0
Failure without fluid change: 0
Right?
Old 05-12-14, 06:06 AM
  #185
XJSFan
XJSFan's Avatar
I have 6 quarts of WS and may do it this week... I'm thinking of draining 3 quarts and replacing it with 3. That makes it easy. I'll then use the remaining 3 quarts later this summer.
Old 05-12-14, 08:32 AM
  #186
malrafe3i
malrafe3i's Avatar
there are two bolts that opens with an alenky in the differential the up one is to fill the down one is to drain its on the left side / on the driver side just u need to get your car on a lift
Old 05-12-14, 10:06 AM
  #187
toyo
toyo's Avatar
Are you guys getting the fluid in correct temp range to make sure you are putting in the correct amount and to check the level? If not, you need to!
Old 05-12-14, 12:29 PM
  #188
jimbosr1
jimbosr1's Avatar
i cant believe this thread is still gooooing.
Old 06-30-14, 10:00 AM
  #189
XJSFan
XJSFan's Avatar
HELP...
What size wrench is needed to remove the ATF refill plug? I have tried 7/8(too small), 15/16(too big). This is going to drive me mad. LOL.
Old 06-30-14, 11:09 AM
  #190
jimbosr1
jimbosr1's Avatar
Originally Posted by XJSFan
HELP...
you have to get metric tools
Old 06-30-14, 11:18 AM
  #191
Lavrishevo
Lavrishevo's Avatar
It will never die... LOL Well, it does not help that many dealers instruct owners not to change the transmission fluid. Which, is obviously bad advice for the life of the transmission.
Old 06-30-14, 11:50 AM
  #192
XJSFan
XJSFan's Avatar
I tried a 24mm and it worked. LOL. I was able to drain out 3 quarts and replaced the same amount. The tranny seems smooth as before.
Old 06-30-14, 01:59 PM
  #193
Lavrishevo
Lavrishevo's Avatar
That's a good thing. I have already done mine twice. Each time I could feel a minor improvement in the shifting. The WS synthetic is good stuff but just like engine oil it get dirty and breaks down.
Aisin designed the transmission to be serviced. The reason Lexus called it a lifetime fluid is because they knew you could get to 200k or more and by saying it does not need service it cuts the rated owners cost down.
Old 06-30-14, 10:46 PM
  #194
Pamperme
Pamperme's Avatar
Can u provide proof of this? If so, I'd be interested in it. Should a transmission fail due to following Lexus's instructions, this proof would become critical in a court of law.
Old 07-01-14, 03:34 AM
  #195
toyo
toyo's Avatar
Considering Lexus recommends changing it at 60K under severe service I would say look in the manual. If you read the severe table definition it's pretty much everybody I know.
Quick Reply: 04-06 Sealed Transmission fluid change interval? (The Mother thread)
