HELP Battery installation IS350
Old 04-15-10, 11:11 AM
Wassa786
Wassa786's Avatar
Default HELP Battery installation IS350
Trying to replace the battery on the IS350, I got both terminals off, but the positive (+) one has a lead attached to the plastic and I have no idea how to take it off?
That bolt doesn't look like it wants to come off either...
What to do guys?
here's a pic
Old 04-15-10, 01:04 PM
Wassa786
Wassa786's Avatar
bumppp help ?
Old 04-15-10, 04:11 PM
blk250
blk250's Avatar
spray some wd40 and wait a bit b4 trying loosen it again
Old 04-15-10, 04:32 PM
2006Onyx
2006Onyx's Avatar
I literally had to do this yesterday....
I ended up leaving it on the post, but unclamping the two clamps that hold the two positive wires.
That wasn't easy either, but if you wedge a screwdriver in between the wire and the clamp, you will be able to pop out the clamp. When you do that, you can remove the plastic battery cage.
Hopefully you won't have as much of a problem as I did with the new battery. The replacement I bought was a little bit taller (Maybe a quarter of an inch) and it was extremely difficult to get the hold-down bar on.
Don't forget after you do this you gotta go to each window and manually lower/raise each window (at the door) otherwise only the drivers window will work at the master switch (And none will have auto up/down)
Good luck!
Old 04-16-10, 12:42 AM
Wassa786
Wassa786's Avatar
took it to walmart, guy unclips hook in literally 10seconds...there is a metal piece that hooks onto the plastic lead.
should've seen that -__-
Old 06-12-10, 02:35 PM
Janizary
Janizary's Avatar
Had to replace the battery today. Saw this post and thought I'd post a pic of the clips. You need to insert a screwdriver in the slot(s) and it will pop off, repeat on other side. The only issue is it is very tight in there/awkward to get at. Took me a few minutes to figure out how to get even my short screwdriver down alongside the box.
Attached Thumbnails HELP Battery installation IS350-batteryboxclipclosed.jpg   HELP Battery installation IS350-batteryboxclip1.jpg
Old 09-10-10, 09:42 AM
typhoon44
typhoon44's Avatar
I had to replace my battery today and understanding how this clamp worked helped but I could not get a short slotted screw driver to open it. I discovered taking a pair of needle nose pliers and pulling in the direction its supposed to open popped them right off in about 5 seconds. I wished I had done this first and not wasted 20 minutes trying to get that thing off. They popped right back into place when I put the battery case back on.
aeiou2006
11-05-17 06:08 PM
sleepy1711
03-07-13 07:33 PM
odj1989
12-04-11 11:34 PM
np20412
Maintenance
08-25-03 03:35 PM
Quick Reply: HELP Battery installation IS350
