Rear End help please! uncontrollable swaying
Old 04-16-10, 08:57 PM
BigGreene
BigGreene's Avatar
Default Rear End help please! uncontrollable swaying
there is somethig seriously wrong with my car.
its a 92 sc300 auto and 100% stock.
when i drive regardless of speed i hit the slightest bump or inperfection in the road the whole rear end of my car jerks HARD!.
if im going steady at anything above 20 the car rocks left to right pretty hard i mean i wiegh almost 300 lbs. and it almost moves me out of the seat.. all the tires are new and balanced.
i dont have any idea what it could be and i have never owned a RWD car.
its almost as though my car is fishtailing.. its bad bad.
the guy at the shop cant figure out what it is so i come here for true lexus help.
any help would be greatly appreciated.
Old 04-17-10, 04:41 PM
zhillz
zhillz's Avatar
Your sway bar is disconnected in some way.
Old 04-17-10, 07:35 PM
Pipe
Pipe's Avatar
When was the last time you changed your shocks??
Old 04-17-10, 08:06 PM
BigGreene
BigGreene's Avatar
I bought the car for 1500 3 days ago and he sold it to me because of this problem. But I'll look into the sway bar thing and I'll let you know what I find thanks for the info though. Any other ideas what it could be?
Old 04-17-10, 08:13 PM
Pipe
Pipe's Avatar
Lmao!!!! Dude i bought mine last month!!
The guy wanted $1500 i slapped him 1K and drove it off first thing i noticed the brake pedal going all the way to the floor and mind you i live 60 miles away,
The car was jarring all over the road ESP when i hit a bump, Next morning i looked it over and it turns out to be bad dampers thats why i told you to check em out.
Old 04-17-10, 09:50 PM
Maeve
Maeve's Avatar
It could also be a blown shocks. I had this problem before.
Old 04-17-10, 10:20 PM
BigGreene
BigGreene's Avatar
ill check both of them. as of right now i am down right clueless. but i will check all these options monday as thats my first day off and ill have a chance to rip it all apart
Old 04-18-10, 06:20 AM
good2go
good2go's Avatar
the guy at the shop cant figure out what it is ...
I think you need to look for a new shop too
Old 04-18-10, 06:28 AM
Pipe
Pipe's Avatar
Dampers = Shocks , Same thing.
Old 04-18-10, 04:37 PM
zhillz
zhillz's Avatar
How in the hell would bad shocks make your car sway side to side?
When i lowered my car my sway bar didnt get tightened all the way and came loose and had the problem you are describing but not as bad.
Old 04-18-10, 06:15 PM
Maeve
Maeve's Avatar
A worn shock can create an excessive rebound on a tire/wheel on a rough road. The wheel will hop too often and when it hits back the road surface, it will push the weight of the car to the sides. Tires, worn out bushings will also add to this "sway side to side" problem.
Old 04-18-10, 06:39 PM
Pipe
Pipe's Avatar
what he said !!
Old 04-18-10, 07:06 PM
zhillz
zhillz's Avatar
Bouncing is up an down with worn shocks. I guess if every bushing under your car was shot this might happen unless your hitting bad dips with one side of the car only.
Old 04-18-10, 09:41 PM
BigGreene
BigGreene's Avatar
ok so it seems like i need to check the sway bar. if it is disconnected what exactly would i need to connect it? or better asked
what connects the sway bar to the frame
Old 04-18-10, 10:06 PM
GSteg
GSteg's Avatar
You need to check the end of the sway bar. It should be connected to the end-links. You'll see it.
Quick Reply: Rear End help please! uncontrollable swaying
