WD40 safe on car paint?
Old 04-26-10, 06:09 PM
flektone
flektone's Avatar
Default WD40 safe on car paint?
I just bought a used IS that has some paint overspray on in. I tried claying which removed some of the smaller specs but takes forever. WD40 seems to work alot better. I tested a couple spots and wiped away quickly with a damp cloth. It doesnt seem to damage the surface at all. Just wana see what you guys think before I do the rest of the car.
Old 04-27-10, 12:44 AM
GSteg
GSteg's Avatar
WD-40 has recommended their product for removing bugs, tar, etc off of automotive paint.
Not sure if it's safe, but I've had WD-40 accidentally sprayed on my car and there was no ill-effect.
WD-40 is mainly a water displacer anyways. It's nothing strong like PB-Blaster or Kroil.
Old 04-27-10, 03:57 PM
Guitarman
Guitarman's Avatar
There's no history that it affects cured urethane enamels whatsoever.
Yes, safe.
Great for removing tar.
Old 04-28-10, 08:14 PM
Red Bully
Red Bully's Avatar
try useing some clay
Old 04-30-10, 11:45 AM
Lexis61509
Lexis61509's Avatar
"WD-40 is mainly a water displacer anyways."
100% correct, but I still would make sure that I cleaned the area well with soap and water after you get the bugs off. Then wax the area because the WD - 40 can eat away at the wax if not cleaned up.
Old 05-14-10, 01:16 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
I saw a copy of an email at work last week describing the use of WD-40.. There were 40 uses and removing luv bugs was one of them without harming the paint.. I couldn't believe the uses for this stuff..
Old 05-14-10, 03:52 PM
pocky
mooncake master
pocky's Avatar
I love using WD-40! It takes almost all the grimmy stubborn dirt off! For even harder dirt, I use Acetone. But that one you gotta be careful. If you rub really hard, you'll rub the paint right off. Acetone does wonders.
Old 05-14-10, 05:38 PM
mou
mou's Avatar
I read that it says it'll help prevent mud and road tar from sticking, anyone try that yet?
Old 05-14-10, 09:29 PM
01LEXPL
01LEXPL's Avatar
I've used carb cleaner on paint...
Got undercoating overspray that caught the wind. Had to spray half the car with the stuff to clean it off!
No ill effect.
Old 05-18-10, 01:43 PM
Infamous 1
Infamous 1's Avatar
When used on wheel wells, yes it does work.
Old 05-26-10, 05:32 PM
habeeb89
habeeb89's Avatar
It surprisingly works great on removing stubborn dead bugs
Old 02-20-23, 08:00 PM
noahenholm
2nd gear
noahenholm's Avatar
Yes. Wd40 may be used to get bugs off of an automobile without harming the paint. But, because WD-40 is based on mineral oil, you must wipe off extra oil to prevent dust from gathering on your car's surface.
Old 02-22-23, 01:55 PM
Jakerin
Jakerin's Avatar
Whatever else WD40 is, it’s also a solvent and should be removed by cleaning the surface it is applied to.
05RX330AWD
07-17-17 11:20 AM
jonmanch
05-23-16 04:32 PM
kingCUONG
15
01-19-12 06:14 AM
NguyenD408
03-22-09 12:44 PM
Jmai22
02-01-03 05:57 PM
Quick Reply: WD40 safe on car paint?
