Tensioner pulley replacement?
Old 06-27-10, 09:54 PM
mark98ls40
mark98ls40's Avatar
Default Tensioner pulley replacement?
Squealing sound coming from tensioner pulley with AC on.
Can you just unbolt the pulley & replace the pulley or do you have to replace the whole tensioner unit if the pulley bearings are squealing?
Do the pulley & bearings come together as one part?
I researched the threads on this but didn't find a definite answer.
Old 06-27-10, 10:01 PM
LiCelsior
Retired
LiCelsior's Avatar
belt tensioner? u gotta replace the whole assembly. www.rockauto.com has great prices.
gotta replace mine tomorrow also.
Old 06-28-10, 08:00 AM
mark98ls40
mark98ls40's Avatar
Thanks. Ya, I figured that would be. I replaced other pulleys on cars, but just the pulley part.
Old 06-28-10, 03:06 PM
nthach
nthach's Avatar
Word of advice - use a Toyota OEM or a Goodyear tensioner. Dayco ones WILL NOT FIT. If you can do so safely and without distorting the original pulley, I would press in a new bearing in the old pulley.
Old 06-28-10, 05:19 PM
mark98ls40
mark98ls40's Avatar
Good to know about Dayco. Are their belts any good?
Can you just remove the old pulley and press in new bearing & reinstall on old tensioner arm?
Old 06-28-10, 07:01 PM
LiCelsior
Retired
LiCelsior's Avatar
get Gates belts and tensioner.
Old 06-29-10, 07:56 AM
mark98ls40
mark98ls40's Avatar
Thanks for the info.
Old 06-29-10, 10:46 AM
damon
damon's Avatar
Bearing only replacement has been done & posted here.
Old 06-17-14, 07:46 PM
justincook
justincook's Avatar
Dayco pulley still doesn't fit. Autozone is still stocking it claiming it will fit. I showed them that it does not work.... they shrugged, put it back on the shelf and told me to go to Oreillys.
Gates 36119 worked like a champ.
Old 06-20-14, 12:22 AM
Tiagz
Tiagz's Avatar
I went to my local Pick n Pull and couldn't crack the tensioner loose so just took the pulley. 3$ vs arounnd 40 for replacing the whole assembly with aftermarket
its a left hand thread so you need to turn it right to crack the bolt off is the only thing different about it.
Old 10-09-15, 12:47 PM
drgerry
drgerry's Avatar
Default Where is this post?
Well, if it is . . . . it's hidden pretty good. I can't find it!!!! Can someone please post a link?
Old 10-09-15, 02:22 PM
Nishy
Nishy's Avatar
Here ya go
Old 10-15-15, 08:43 AM
drgerry
drgerry's Avatar
Thanks !!!
Old 10-16-15, 08:27 AM
Daspyda
Daspyda's Avatar
IIRC, I did this last year and it was just a pulley. Took 10 min.
dashan
21
03-10-18 02:25 PM
ColdFusion
06-04-16 07:29 PM
synrgy350
04-22-16 04:11 PM
meis250
05-09-15 08:24 AM
-J-P-L-
Performance & Maintenance
04-29-08 08:55 PM
Quick Reply: Tensioner pulley replacement?
