Power Driver Window won't stay up
Old 06-29-10, 04:52 PM
doverrx330
doverrx330's Avatar
Default Power Driver Window won't stay up
I've look on threads but did not find this issue. My driver window will go up after activating the switch, that's not the issue. The issue is it will go all the way up until it touches the top but come right back down as if it sensed something is blocking it. It stops half was when it comes down. When I activate the switch for it to go up and press outward slightly on the top of the window until it closes, its stay closed. So, before someone sarcastically suggests I can solve this by pressing the window as it goes up, has anyone experienced this and what was your solution.
Old 06-29-10, 05:10 PM
salimshah
salimshah's Avatar
Dont get mad
search on window found this for me:
https://www.clublexus.com/forums/rx-...teresting.html
Tell us if this does not solve your problem.
Salim
Old 07-29-10, 07:03 PM
jimbonuttz
jimbonuttz's Avatar
im having this same issue, were you able to ever figure out what was wrong?
Old 07-30-10, 05:29 AM
RX330inFL
RX330inFL's Avatar
Disconnect the battery for a bit. Worth a try.
Old 08-02-10, 11:27 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
you just need to reset the windows....
Old 08-02-10, 12:18 PM
mandyfig
mandyfig's Avatar
Have you resolved this issue? Did the re-set fix it?
Old 08-03-10, 05:46 PM
doverrx330
doverrx330's Avatar
i've tried to reset the windows as outlined in the manual. it will work properly sometimes by itself -- mostly in the morning after sitting all night but as the day progresses, it acts up; must be a glitch in the system. I can live with it.
Old 08-03-10, 06:07 PM
salimshah
salimshah's Avatar
How about resetting the window later in the day when it acts up. This will program slightly more torque in the pinch protection sensor.
Salim
Old 08-03-10, 06:10 PM
kiwi
kiwi's Avatar
you need to lube the window run channels and possibly re-calibrate the switch.
i would recommend going to the dealer, they should lube it for you for free. or, go to an auto parts store and pick up a can of silicone spray, dont use WD40, that stuf is junk.
LS2k
06-25-23 06:59 AM
xiaowen
06-05-12 11:57 AM
simpsonn
02-16-10 09:04 AM
GSing430
07-09-08 06:43 PM
Downfall75
06-07-08 09:28 PM
Quick Reply: Power Driver Window won't stay up
