Lights don't blink when I unlock/lock my car with OEM remote
Old 08-04-10, 09:46 AM
howardtan
howardtan's Avatar
Default Lights don't blink when I unlock/lock my car with OEM remote
What's goin on Community,
I have an issue regarding my headlights/tail lights. When I unlock/lock the car, using the OEM remote, my lights do not blink anymore. I did a search on the forum and did not come up with anything. If anyone knows how to fix this issue, please post up.
Old 08-04-10, 10:51 AM
RMMGS4
Northern California Regional Officer
RMMGS4's Avatar
Try locking the doors on your remote, then go and manually check to see if all the doors actually locked. When a door actuator goes out and the door won't lock then the lights won't blink.
Try this first, before checking other things.
Old 08-04-10, 02:37 PM
dungut
dungut's Avatar
Also make sure your hazard switch is plugged in and functioning properly. Without the switch, the turns will work like normal, but the lights will not flash for the alarm. I figured it out when I bought my car.
Old 08-05-10, 09:54 AM
howardtan
howardtan's Avatar
I think this is the issue, I don't have it plugged in because I am in the process of installing an avic d3 (in which I get no sound from).
Thanks to the both of you for your help!
Old 07-06-19, 05:57 PM
Casey916
Casey916's Avatar
Default Have same issue with light not blinking when setting alarm
Hi i bought a 1994 lexus es300 and it cane with factory alarm. And factory key that has the one button push to lock and unlock doors..when i go to lock the car and im guseing thats making the alarm set too because the red dash lights comes on.. My isse is non of my outside lights or horn peep when I do this to let you now thrme doors are lock and alarm is set.. But here is thing i dont now if this model 94 lexus es300 even does that at all.. Or is it just for later years and other years and models
yellow2112
05-13-14 06:04 PM
DrDan
RX - 1st Gen (1999-2003)
06-10-13 11:45 AM
eskae3
08-17-11 02:13 PM
Rezaxxed
09-08-08 05:39 PM
TMitchell
03-23-01 11:02 AM
Quick Reply: Lights don't blink when I unlock/lock my car with OEM remote
