i want to make my sc300 faster???
Old 09-06-10, 08:41 AM
trini9227
trini9227's Avatar
Default i want to make my sc300 faster???
i just got my sc300 with the 2jzge, i want to keep the stock motor and do things to it, any suggestions? what turbo kit should i put on? or anything that will make it faster becides the turbo kit? parts?. whats the first thing i should do to it?
Old 09-06-10, 11:10 AM
turbodremz
turbodremz's Avatar
Have you attempted to search here on the forums at all??
First thing to do, is maintenance. No point in trying to make it fast if it isnt healthy..not doing maintenance first is like taking Viagra when you have a bum ticker.
Search the following: NA-T, GTE swap, BFI (for n/a), XS Power (decent turbo kit), Dave-H turbo kits (better than the XS Power).
But bottom line, is how deep are your pockets? how much power do you want to make? What are your final goals for the car? How mechanically inclined are you? Do you want to go na-t or do a swap? auto, 5-speed, or 6-speed? W58 going to suffice? or do you need an R154, or a V160/161? What engine management do you want to use? How much boost? Injector sizes?
There is more that goes into this than just simply saying I want more power. Search, read, search some more, teach yourself the basics, do your maintenance, go to clubna-t.com register and search and read some more. Decide what you want with the car, and determine if your engine can handle it.
Old 09-06-10, 12:11 PM
trini9227
trini9227's Avatar
[QUOTE=turbodremz;5768015]Have you attempted to search here on the forums at all??
There is more that goes into this than just simply saying I want more power. Search, read, search some more, teach yourself the basics, do your maintenance, go to clubna-t.com register and search and read some more. Decide what you want with the car, and determine if your engine can handle it.[/QUO
thanks alot man, really usefull info, i wanna keep the auto tranny for now, im looking for around 300 to 400whp. do you thinks its better to get the turbo kit, or buy everything seperate. how much did your na-t cost?
Old 09-06-10, 01:27 PM
turbodremz
turbodremz's Avatar
Well the stock auto isnt good for anything more than 325hp, anything more and your pushing its limits. 9psi on stock compression is the most I have really seen run on stock compression and auto transmissions, and that is all I have been running since I went na-t, but am in the process of going for double.
IMHO, piece your own kit together. Keep the turbo, wastegate, bov, and other VITAL parts either new, or good USED name brand parts, such as Turbonetics, Garrett, Holset, TIAL, HKS, etc.
My na-t right now, I would have to estimate right around $2200 and counting, but other than the trans and compression, I can easily support 400+rwhp.
Best thing to do, is shop around. Check the classifieds here on CL, Supraforums.com, clubna-t.com and find the parts you will need and give yourself an estimate of how much your going to spend. A good na-t kit can be had for around $1500, but an EXCELLENT kit with everything is going to range from $2500-5k depending on what and where you get your parts.
yell0w
04-28-13 12:24 PM
Widebody00
05-25-12 04:54 AM
1992 SC300
17
02-13-07 10:15 PM
assasin123
07-10-06 02:37 PM
LeXuSrAcIn
11-18-05 08:24 PM
Quick Reply: i want to make my sc300 faster???
