Tpms Light Will Not Turn Off After Air is Refilled
Old 09-19-10, 10:51 PM
Phresh2010
Phresh2010's Avatar
Default Tpms Light Will Not Turn Off After Air is Refilled
So a week ago I saw that my tpms light was flashing, i refilled all my tires with the recommended psi (35 front 38 rear for my AWD), now the light still flashes and will not go away. I have tried searching with no luck, does anyone know how to turn it off?
Old 09-19-10, 11:25 PM
sangomaru
sangomaru's Avatar
well since you refilled the tires back to the recommended psi, the light should go away after a few minutes. also, is the light flashing and then becomes solid, or just flashing?
Old 09-20-10, 12:32 AM
Phresh2010
Phresh2010's Avatar
^^it flashes when the car turns on and becomes solid after a minute, it will not turn off and i have checked the tire pressure again, still 35 front, 38 rear ;/
Old 09-20-10, 01:57 AM
Frosty250
Frosty250's Avatar
try driving a few miles so it updates. the light should disappear afterwards.
Old 09-20-10, 03:38 AM
kumquatism
kumquatism's Avatar
I had a similar problem with mine. I pumped it up, and the TPMS wouldn't turn off. Being lazy, I left it that way, yet it never ended up turning off. It ended up being on for a good few months.
I actually finally got it to turn off by re-initializing the system today. It's in the manual. You make sure the tires are pumped up according to what you want to initialize it at. Turn on the engine, and press the arrows until the screen INITIAL PRESSURE or something shows, then you press the ON/OFF button and hold it for a few seconds. Not sure if it's going to mess up with TPMS system, but it worked in turning off the warning light.
Old 09-20-10, 09:35 AM
new.era.13
new.era.13's Avatar
maybe its the spare tire? correct me if im wrong, dont know for sure if the spare has tpms sensor.
Old 09-20-10, 10:07 AM
laobo979
laobo979's Avatar
make sure you didnt set it to your 2nd set of tpms setting on your dash cause then it wont read your current sensor now and will stay on
Old 09-20-10, 11:12 AM
SC400MAN
SC400MAN's Avatar
The spare might also be low, as someone above said.
check that, too, and then drive it for a few miles, it should go out.
Old 09-20-10, 11:15 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
The spare doesn't have any impact on the TPMS. There is no sensor in it.
Old 09-20-10, 11:23 AM
E6BAV8R
E6BAV8R's Avatar
Reset the pressure that sets the TPMS off. Instructions on how to do it are in the manual.
Old 09-20-10, 10:37 PM
tnogi
tnogi's Avatar
^ I have to try that cuz my TPMS warning light wont
go off aswell...
toHn
SALTY2
RX - 3rd Gen (2010-2015)
18
11-08-19 01:42 PM
GmanSC
01-23-19 06:14 PM
maarp
09-11-18 03:57 AM
RCsGX
GX - 1st Gen (2004-2009)
10-13-13 02:29 PM
edbarrows
12
01-24-12 07:25 PM
Quick Reply: Tpms Light Will Not Turn Off After Air is Refilled
