How to remove roof rack crossbars?
Old 10-05-10, 08:12 AM
prowler97
prowler97's Avatar
Default How to remove roof rack crossbars?
Does anyone know how or if the roof rack cross bars can be removed from RX330/350/400h? If so please explain?
Old 10-05-10, 09:15 AM
redrocks
redrocks's Avatar
Search the forum, there's a DIY.
Old 10-06-10, 07:37 AM
draco
draco's Avatar
Also be careful when removing them. The plastic caps at the end of each rail have a yellow christmas tree plug that can break if not done properly and if you lose it will cost a $120 (Australian) to replace. I made the mistake of not checking mine, thinking they would slide out (as per the instruction manual), and found that mine were actually Rhino Racks (aftermarket) that clamped onto the rails.
Old 10-06-10, 12:57 PM
prowler97
prowler97's Avatar
I removed the rear plastic cover ends of the roof rack by sliding them back. I then slide the cross bars back and out of the track. I noticed that one of the cross bars was difficult to move because the locking pin mechanism is broken. I used a flat head screwdriver to release the pin.
Does anyone know where I can find a TSB for the crossbars for 2003-2009 RX 330/350/400h?
Old 10-06-10, 01:29 PM
mandyfig
mandyfig's Avatar
It should be on the same DIY post.
Old 10-09-10, 06:10 AM
vg1134
vg1134's Avatar
search tab is your friend...........
Old 10-09-10, 06:46 AM
mandyfig
mandyfig's Avatar
Got that right!
Old 10-20-10, 02:16 PM
onedukeof
onedukeof's Avatar
Anyone know if the crossbars from 2007 RX350 will fit a 2010 RX 350? Thanks
Old 10-20-10, 03:26 PM
mandyfig
mandyfig's Avatar
No they will not fit, entirely different design.
Old 12-04-10, 08:56 AM
chuckl65
chuckl65's Avatar
I'm having trouble getting the end caps removed and could not find a DIY on it. Can you or someone point me in the right direction?
Chuck
Old 12-04-10, 01:47 PM
chuckl65
chuckl65's Avatar
Searched again and found a thread.
https://www.clublexus.com/forums/rx-...oss-rails.html
Chuck
Old 12-06-10, 08:44 AM
mandyfig
mandyfig's Avatar
Chuck
Is yours a 2nd Gen?
Old 12-06-10, 10:08 AM
chuckl65
chuckl65's Avatar
Mandyfig,
I'm not familiar with the 2nd generation, but mine is a 2010. I've read the other threads and still can't get the cover off. I'm afraid to pull and pry to hard, particularly when others say that when to get the hang of it, it's real easy. Any help would be appreciated.
Chuck
Old 12-06-10, 12:43 PM
mandyfig
mandyfig's Avatar
Sorry Chuck, have no idea about the 2010's.
cmichael
05-26-20 02:00 PM
thelew67
RX - 3rd Gen (2010-2015)
12
05-21-14 03:32 PM
kutsyy
GX - 1st Gen (2004-2009)
04-14-08 03:41 PM
NewEngland
05-31-07 07:09 PM
Quick Reply: How to remove roof rack crossbars?
