Help with AEM FIC 6 1jzgte SC400
Old 10-17-10, 07:56 PM
grhed1jz
grhed1jz's Avatar
Default Help with AEM FIC 6 1jzgte SC400
I have searched for hours looking for the information i need. i purchased the car with the FIC install, well to find it is partailly installed. Its a mess with only 1 2 3 injectors wired in. and i see no O2 sensor wired in either. I am also dealing with the the rewired 1jz swap too. i checked to maps and only the map fuel trim had inputs. the car was never dyno tuned. it still runs good and strong on 12 pounds and other mods. i couldnt see the FC being able to do anything with no O2 or injectors 4 5 6 not wired in so im thinking it running of the stock ecu still. If anyone has any information on any 1zjgte (jzz30) and AEM FIC 6, wiring diagrams, directions, maps, ect....... i would greatly appreciat it.
Old 10-21-10, 10:30 PM
frankdms
frankdms's Avatar
Well~ You seem to have a mess on your hands. First you should google 1jzgte ecm diagram to get an idea of where to start. You will find more than one 1j ecu diagram, don't worry, if you follow the wiring out of the pcm conector you can find out which one to use. It is best to search your 1j ecu #'s. You will need to rewire three if the fuel injectors to the F/IC. The fic's injector drivers will burn up running batch fire (seems to have been a problem with the 1j's) It is fairly simple to run three wires from the fic to the injectors and rewire the factory three to only control three. (I will find some more info and post it up in a few)
I will post up a new thread with my 2jzge fic install with the diagrams and the directions in the next week or so when I have mine dialed in.
Old 10-21-10, 10:42 PM
frankdms
frankdms's Avatar
http://supraforums.com/forum/showthread.php?p=7881327!
Aempower.com in the forums section there is great info as well. Too bad the older sc's do not have a plug and play...
Old 10-22-10, 12:39 PM
Ali SC3
Ali SC3's Avatar
that seems odd that its running fine like that at 12lbs of boost if it was really missing 3 injectors.
I believe the older 1j'z use batch fire injection, that could explain why there are only 3 wires at the ecu. if thats the case its normal, 2 injectors are paired together to make 3 sets = 6 working injectors.
Old 10-23-10, 06:35 PM
frankdms
frankdms's Avatar
Here is a pic to help, can be found on same SF link.
Old 10-24-10, 07:18 AM
grhed1jz
grhed1jz's Avatar
i have already looked up the ecu pinout. there is only 3 injector pins so its a batch fire system. i cant use the ecu number because the sticker with the number is too faded to see. im almost sure it a soarer ecu because its a 4 pins high connectors going into the ecu. all the other where only 2 high. i would like to see i wiring diagram of one of our guy's setup. all the help is greatly appreciated.
Old 10-25-10, 10:52 PM
frankdms
frankdms's Avatar
^I will get them up shortly. As for the batch fire, you will use 6 outputs going to the injectors and three to the ecu from the f/ic.
I have two 1j's and I will get you a pic of both. One is a jdm mk3 setup and the other ~who knows?
Old 11-03-10, 09:45 PM
frankdms
frankdms's Avatar
Top is a soarer ecu, bottom is a supra (both 1jzgte) get a diagram for the correct ecu.
Old 11-19-10, 11:57 PM
frankdms
frankdms's Avatar
more info. First pic is supra 1jz, second is soarer.
Attached Thumbnails Help with AEM FIC 6 1jzgte SC400-1jzecu_diagram.jpg   Help with AEM FIC 6 1jzgte SC400-jzz30soarerecupinout1.jpg
Old 12-07-10, 03:56 PM
grhed1jz
grhed1jz's Avatar
sorry for no resent responses been very busy. (work) i have the soarer ecu and it is running a batch fire ijectors. i have had the car for over a year with no problems with the drivers burning out yet. when i get enough time to tear the harness out i will be rewiring those injectors. i still cant tune using the the o2 map. i have research online i cant find how people got their o2 maps set up to be able to tune with it. if any body has i tune for a 1jzgte and can send it so i can see/play around with it, that would help.
Old 01-11-11, 04:10 PM
slopra
slopra's Avatar
I've been searching for something to. I need schematic for the ecm itself. Does anyone have this info? Also, were are the injector drivers in the ecm? What do they look like? How many are there?
thanks, Wes
Sabersupra
03-16-17 08:13 PM
StuntKing
13
12-13-12 10:03 PM
Drew1jz92
23
08-05-11 01:07 PM
vangb2
09-23-09 05:18 AM
pmpdaddyt
02-27-09 06:39 PM
Quick Reply: Help with AEM FIC 6 1jzgte SC400
