heated seat problem lexus es300 1998
Old 11-20-10, 01:02 PM
marcoes300
marcoes300's Avatar
Default heated seat problem lexus es300 1998
hi my heated seat dont work , i looked at all fuses and there're all ok , any solution ?
(sorry for my english , i live in montreal (frenche))
ty !
marc
Old 11-21-10, 11:39 AM
PFB
PFB's Avatar
Does your heated switch light turn on when set to high or low? Do both the cushion part as well as the back of the seat not heat up? Does the other seat heat up?
I am also in Montreal
Phil
Old 11-21-10, 04:20 PM
marcoes300
marcoes300's Avatar
yea the light turn on ( on the button) but i dont know what you mean by high and low cuz i have no choice i put it on and i put it again to turn off... and both seat dosnt work
Old 11-24-10, 06:31 PM
marcoes300
marcoes300's Avatar
still need help !!
Old 11-24-10, 08:55 PM
Received 2,705 Likes on 2,290 Posts
You need to check the heater elements with a test meter, and also test that there is voltage getting to the elements. But unfortunately, the elements themselves may be burnt out, it is fairly common.
Old 11-25-10, 07:27 AM
marcoes300
marcoes300's Avatar
is it expensive ?
Old 11-25-10, 08:09 AM
PFB
PFB's Avatar
You definitely will need to check the heating elements, as suggested by Lexus2000 above. However it is unlikely that both heating elements are burned out. (The seat cushion as well as the back). So its more likely that you have an electrical problem (Switch, Wiring, Fuse, etc..)
Does the passenger heated seat work??
Old 11-25-10, 08:28 AM
marcoes300
marcoes300's Avatar
no, both seat doesnt heat but the button's light work ....
Old 11-25-10, 11:38 AM
sphillips
sphillips's Avatar
i would check voltage at the connector under the seat. If voltage there, then probably elements. If no voltage, check connector at switch
Old 11-25-10, 02:08 PM
marcoes300
marcoes300's Avatar
i dont know where to find all the **** under the seat , and i dont know where to chek the voltage !
Old 11-26-10, 04:18 PM
sphillips
sphillips's Avatar
If both seats are inop, and switch lites activate when pushed, then I would check the elements as well. If you look at the wiring diagram in the manual, power splits at splice 19 and parallels to both switches. After power passes thru both switches, circuit is completed to ground thru splices 17 & 18.
Old 11-28-10, 11:00 AM
sphillips
sphillips's Avatar
Found this technical Service Bulletin for the '97 ES300, it may help. Below is a quote from it:
1. Lift up the console panel from the
Procedure back side using a screwdriver.
NOTE:
Take care not to damage the panel.
Place tape over the screwdriver tip
before attempting this procedure.
2. Inspect the seat heater switch
connectors:
�� The BLACK seat heater switch
connector should be installed in the
DRIVER’S side switch.
�� The BLUE seat heater switch
PASSENGER’S side switch.
3. Reverse position of connectors as
necessary.
4. Reinstall the console panel
Old 12-02-10, 01:44 PM
marcoes300
marcoes300's Avatar
ok , i really dont know what is what under the seat ... somebody have a pic to help me ?
Old 12-02-10, 03:58 PM
KLF
KLF's Avatar
Don't touch anything that has yellow plastic loom/sheath around it! That's the wiring for the air bags!
Old 12-02-10, 07:08 PM
sphillips
sphillips's Avatar
Marcoes,
Check the connectors at the switches first, that the easiest-blue connector driver side, black connector passenger side
Quick Reply: heated seat problem lexus es300 1998
