High Beam lights don't work - HELP!!
Old 11-29-10, 11:20 AM
durian
durian's Avatar
Talking High Beam lights don't work - HELP!!
I have a 2002 Lexus ES300. Recently I noticed the high beam headlights do not work. The blue high beam indicator light on the dash do not light up. I then took out the high beam bulbs and tested them, and they seem OK. I measured for 12V at the light socket with the high beam turned on, and I do not see 12V there. Someone told me that the combo switch behind the steering wheel may be bad.
I recently had some work done at the passenger side rear lights. Could it somehow be related?
Help please...
Old 12-14-10, 02:36 PM
avspecguy
avspecguy's Avatar
Default headlights...
It's just a thought but the headlights on my es300 are connected to a relay located near the battery. If the relay is bad, which happens occasionally they won't work. Check to see if there's a relay for the low beams that might be interchangeable so you can just switch the relays and see if the problem follows before you go buy a new one. This is a strong possibility if both headlights are not working...
Good luck!
Medic1278
RX - 1st Gen (1999-2003)
11-30-14 08:54 PM
skint agai
10-14-12 12:20 PM
1strx300
09-19-10 07:53 AM
Quick Reply: High Beam lights don't work - HELP!!
