18x9 30-offset 18x10 40-offset
Old 01-11-11, 07:26 PM
IS250Slvr
IS250Slvr's Avatar
Default 18x9 30-offset 18x10 40-offset
i am looking at some aftermarket wheels
Front 18x9 30-offset
Rear 18x10 40-offset
i was wondering if i can get some input if the offset is a bit too much can anyone with aftermarket wheels please give me some input on what you think
Thanks
Old 01-11-11, 07:38 PM
projectdna
projectdna's Avatar
you can check the "will those wheels fit?" thread.
but in the event you can't find your answer after searching through that thread, you can always ask if those wheel specs will fit in the above-mentioned thread.
personally, i think it will fit, but i don't know if fender work will be involved.
best of luck.
Old 01-11-11, 07:49 PM
IS250Slvr
IS250Slvr's Avatar
thanks i will look into the link appreciate it
Old 01-11-11, 09:34 PM
Sffd103
Fire Slayer
Sffd103's Avatar
I'm running +30 front and rear on a 19" wheel. you should be fine. You may need to roll the front fender on get a 225 tire in front.
Old 01-11-11, 09:54 PM
lexusis305
lexusis305's Avatar
Dont do 18" rims its going to look super small or you have to slam the **** out of it . Go for 19" or 20" not 18"for that get spacer and lower it on stock and save the money
Old 01-12-11, 06:08 AM
IS250Slvr
IS250Slvr's Avatar
thanks for the input everyone i might just wait and get 19's
specie
Suspension and Brakes
09-08-13 02:03 PM
sincityIS
07-11-07 07:26 PM
2jzz30
13
04-18-07 07:50 PM
trangk
Wheels, Tires & Brakes Forum
10-05-06 02:53 PM
jtgs400
04-10-06 11:39 AM
Quick Reply: 18x9 30-offset 18x10 40-offset
