2002 SC430 Navigation Antenna
Old 01-26-11, 05:54 PM
gabeLex
gabeLex's Avatar
Default 2002 SC430 Navigation Antenna
Hello all,
Can anyone guide me in the right direction of finding out how to replace the navigation antenna in the factory unit that came with the 2002 SC430?
In Diagnostics mode, there's no satellites detected...this means there's no signal to the unit.
If anyone has an inexpensive solution, please let me know.
Thanks!
Old 01-26-11, 07:22 PM
VVTiBob
VVTiBob's Avatar
Well the first obvious question is do you have line of sight to the sky? Believe it or not some people attempt to run the diagnostics from underground parking, or inside the garage.
The Nav antenna is located under the dash behind the display. Go to this thread, item #3....https://www.clublexus.com/forums/sc-...ntenna-is.html
Old 01-27-11, 03:31 AM
gabeLex
gabeLex's Avatar
Thanks,
I checked it outside in clear skies, and there's no signal from anywhere. I guess it's time for me to roll up my sleeves and remove the nav system.
Old 01-27-11, 07:33 AM
Habious
Habious's Avatar
I've had my Nav screen out. It's a PITA to get out of there.
You have to pull the climate module, the wood-covered side vent on the left side of the screen, the long wood panel on the right side of the screen, and there are like 4 bolts to get the whole assembly loose.
Old 01-27-11, 09:04 AM
cjs18
cjs18's Avatar
The scope of work is more than removing the nav unit. Unfortunately the antenna is located behind some AC ductwork and fastened to the underside of the instrument panel safety pad with screws that are applied from the wrong direction to be accessed from inside the car - so the factory procedure is to remove the glareshield and at least half the other stuff in the front of your car. It is a huge undertaking that might make one take a second look at a $200 Garmin unit. Of course as with any of these things there might be shortcuts but it doesn't look easy.
File Type: pdf
Old 01-27-11, 10:24 AM
VVTiBob
VVTiBob's Avatar
Gabe,
I couple of questions that may isolate the problem further... Back in the diagnostic screens
goto the GPS Information screen. What is displayed in the bottom left corner after the word Status: ??????? Just above the word status you should see Measurement Date (GMT). Anything there?
Then onto THE SERVICE check... Right side NAVI-ECU diagnostic screen .... what are the reading? Any DTC codes? Check out this below... asterisk and number tie back to the graphic on the left... Looking for a "40" "41" error code in the *12 area that points to the antenna, otherwise it probable the ECU. I sent you a PM too.
Old 01-27-11, 03:31 PM
gabeLex
gabeLex's Avatar
Status is '--'. The current date time is by GMT, nothing by measurement. How do I get to the service menu?
Old 01-27-11, 03:44 PM
VVTiBob
VVTiBob's Avatar
1.With the car stopped
2 set parking brake
3 turn ingnition to ACC or ON
4 push the display button for the Nav system
5 On the screen you should see a rectangle box between the word "display" at the top left and the contrast control at the bottom left.
Inside the box, touch top left corner, bottom left corner in that order three time in a row.
puts you into service mode
Old 01-27-11, 03:46 PM
VVTiBob
VVTiBob's Avatar
Once in service mode menu, press Unit Check to get to the "NAVI-ECU" in the right column
Old 01-27-11, 05:53 PM
gabeLex
gabeLex's Avatar
Default Images of the service screens
Old 01-27-11, 06:16 PM
VVTiBob
VVTiBob's Avatar
Now that you have a record of the codes, clear them by touching and holding the Code CLR button for 3+ seconds and lets see if the errors return or new error present.
Old 01-28-11, 12:32 AM
gabeLex
gabeLex's Avatar
Will do this step once I receive car back. Had to leave it at dealer to get the TPMS fixed, should get it back soon. So, what does the current codes mean?
Old 01-28-11, 09:21 AM
VVTiBob
VVTiBob's Avatar
Sent you an extensive PM
Old 03-11-11, 02:05 PM
gabeLex
gabeLex's Avatar
I reset statistics and it appears to be a bad antenna.
http://lexus.sewellparts.com/oem-cat...C430-2002.html
That antenna assembly costs $445.79 Part# 86860C . Is it worth it or should i try to go aftermarket?
Need advice
Thanks!
frankgold
12-17-17 10:01 AM
hlovepenn
05-21-16 09:36 PM
ArgylesLF
06-05-12 06:01 AM
robertrios
01-10-11 11:42 AM
Quick Reply: 2002 SC430 Navigation Antenna
