Correct Tire Pressure?
I have the "old" RX330 (2006) but a friend has a new 2010 RX350 and wants to know the recommended cold tire pressure?
Tire Monitor?
TPM-Tire Pressure Monitor data direct from Lexus site: http://www.lexus.com/models/RX/features/safety.html
"Sensors monitor the air pressure of all four tires and send a signal to alert the driver if the tire pressure falls to a critical level [1]. In some Lexus vehicles, sensors monitor the wheel speed to determine if air pressure has reached a certain threshold. Note [1]: The Tire Pressure Monitor System alerts the driver when tire pressure is critically low. For optimal tire wear and performance, tire pressure should be checked regularly with a gauge; do not rely solely on the monitor system. Please see your Owner's Manual for details."
only the 450h has the readouts of the individual tire pressure. the RX350 does not have the readouts on the multi information display and only has a light on the dash that illuminates when it senses low pressure (though doesnt tell you which tire(s) )
Ah, I see! I saw someone's (Anita's?) posted photo showing tire pressures, and search through the manual and click through menus as I might, I couldn't figure out how to replicate that on my RX 350. Thanks, RXSF!
No, I don't play soccer!
BCR, it's accessed through the steering wheel on the 450h. Besides not showing the tire pressure in sequence, it tends to read a pound less. Try getting all four to match too I still use the trusty tire gauge.
tfz_hebe89
10-24-08 03:44 AM
love67
09-10-08 11:09 PM
