2007 ES350 headlight bulb question
Old 02-02-11, 12:54 PM
is250rida
is250rida's Avatar
Default 2007 ES350 headlight bulb question
Hey everyone I just picked up a 2007 ES350... the headlight bulbs went out (H7 halogen) so I bought some replacements.. When I re-installed them the beam of light seems to spread a lot. I barely get any light on the ground.
I've never dealt with a car that had spacers/adapters. And I don't really remember how the bulb came out..
When I put the new bulbs in i had the tab facing down, closed the pin behind the bulb, inserted the spacer/adapter with the rubber boot on it.. then plugged it back up.. is that correct?
I've heard that the spacer/adapter should go on the bulb and then the pin should hold the both together..
The bulb is a bit loose, so i'm not sure..
Thanks for the help in advance!
PDES350
33
12-16-13 06:22 AM
Irish239
11-23-12 06:02 PM
jbone29
04-09-12 05:27 PM
Mr.Stussy
12-28-09 07:46 PM
rhsmd
02-05-07 05:26 PM
Quick Reply: 2007 ES350 headlight bulb question
