where is "bank 1 sensor 1" on es300 1998 for a DIY job?
Old 02-25-11, 07:26 PM
ayroman
ayroman's Avatar
Smile where is "bank 1 sensor 1" on es300 1998 for a DIY job?
"Air/Fuel ratio sensor circuit response malfunction (bank 1 sensor 1)"
i am thinking about buying the O2 sensor for $170 and replacing it myself, instead of paying the mechanic $60 for labor.
I have no idea where it is and if i can replace it without having an access underneath the car.
any suggestions, tips, and exact location of the sensor is highly appreciated. thx
Old 02-25-11, 07:40 PM
AndyG
AndyG's Avatar
Ok, two things I've found recently as my bank 1 sensor 1 is out also:
"1995 Es300 Bank 1 Sensor 1 Oxygen Sensor Replacement Get rid of p0135 check engine code"
http://us.lexusownersclub.com/forums...howtopic=32035
The best way to see exactly where that sensor is is to climb a bit into the bay from the drivers side, looking behind the engine, against the firewall towards the passenger side. You'll see the O2 sensor sticking out with it's attached cable. Yes, it appears to be a pain in the butt to get to.
And you can get the sensor from amazon for an amazing $70.
Denso 234-4622 Oxygen Sensor (Air and Fuel Ratio Sensor)
http://www.amazon.com/Denso-234-4622...1995&carId=011
And according to AutoZone, this is the model number of the proper O2 sensor (before the cat).
Old 02-25-11, 08:16 PM
ayroman
ayroman's Avatar
the price on amazon.com is kinda awesome and looks as any other o2 sensor. I have a California emissions es300 1998, is there any difference in o2 sensor types?
Old 02-25-11, 08:21 PM
AndyG
AndyG's Avatar
I started here at AutoZone as it's about the best local parts joint we've got.
http://www.autozone.com/autozone/
You can add your vehicle and then see parts just for it. In my case, for a 95 ES300, this is the part (the Denso version) that came up:
http://www.autozone.com/autozone/par...5_0_1784_97999
Part number: 234-4622 which is actually the part number from the manufacturer as also seen on the Amazon page:
I would perhaps start by entering your vehicle on AutoZone or Amazon even and seeing what O2 sensors they offer but I was surprised to find it that cheap on Amazon. Your mileage may vary.
For what it's worth, I ordered one off of Amazon just now and it should be here on Tuesday. I'll report in on how the change went with pics and such.
Old 02-26-11, 08:23 AM
KLF
KLF's Avatar
Be VERY VERY careful here. My '98 was also a Cali-spec car, technically you don't have O2 sensors, you have "Air/Fuel Ratio" sensors. They are slightly different. I had to replace both of them on my car, I bought them both from Toyota (I used a VIN from a Camry).
It's a pain to reach the rear one. You will need a special socket, and short stubby extension, and a set of ramps to drive the car up on. I reached it from underneath. I don't remember the torque for installing the new one, I gave away my FSM to a buddy.
Old 02-26-11, 11:08 AM
tomf
tomf's Avatar
Go to the Denso website for aftermarket parts for a 98 ES300 you get the following:
Engine: V6 (3.0L)
VIN: F
234-9007
Images Calif.; Calif.; DENSO is the O.E. Manufacturer / Air Fuel Ratio Sensor N/A Front Left
Engine: V6 (3.0L)
VIN: F
234-9009
Images Calif.; Calif.; DENSO is the O.E. Manufacturer / Air Fuel Ratio Sensor N/A Front Right
I believe the front left is the one you need. Denso Air Fuel Ratio Sensorpart number 234-9007. Also the difference between the too is the length of the wire to the connector. Also Denso is the O.E. Manufacturer.
I put this part in my 99 ES300. It was pretty easy. The hardest part was un-connecting the wiring because of the limited space for you hands. You will also need a O2 sensor socket. I tried using a wrench but there was a bolt in the way that prevented me from turning the sensor. I used one that looked like this http://www.amazon.com/KD-Tools-KDT39...746925&sr=8-17 I bought it from a local auto parts store.
You said your car was a California Model. So you need the parts above. Part number 234-4622 is for non-cal. Here's a link to the Denso website http://www.densoaftermarket.com/cata....php?part=afrs Where you can confirm for yourself.
Old 02-02-15, 08:03 PM
AndyM
AndyM's Avatar
Question Same problem - but what sensors should I buy?
Hi!
I have some of the same codes on my 1998 ES 300. I had the guy at Autozone read the codes for me.
P0171 Bank 1 too lean x4
P1130 (Bank 1 Sensor 1) x 3
P1135 Air/Fuel sensor heater malfunction
P1150 Air/Fuel (Bank 2 Sensor 1)
P1153 Air/Fuel (Bank 2 Sensor 1)
These are for the O2 sensors. I think that is causing the following codes:
P0300 Random Multiple Misfire
P0301 Cylinder 1 Misfire
P0303 Cylinder 3 Misfire
P0305 Cylinder 5 Misfire
So my questions are:
1.) I want to replace BOTH sensors. The one on Bank 1 and the one for Bank 2. Are they different part numbers? Like does Bank 2 have a longer pigtail than Bank 1, or vice-versa? DENSO part number 234-4622.
2.) Is this a good place to purchase from? THMotorsports
3.) How can I tell if my car is a California specification?
4.) What will go wrong if i use the non-California part in a California specified 1998 ES 300? What about the other way around?
5.) I read somewhere that the engines in this generation are bad because of some oil sludge build up problem. Is this true? What is the best way to remove the oil sludge?
Thanks!!!
Old 02-03-15, 01:08 PM
tomf
tomf's Avatar
Go here to find which sensors you need: http://densoautoparts.com/find-my-pa...icle-selection You want the upstream sensors.
Look under your hood for a sticker to determine if it is Cal.
I buy mine from Amazon because I'm a Prime member and get two day shipping.
According to Denso for non Cal the same part number 234-4622 is used for each bank. For the Cal, I believe the sensors are the same but the difference is in the length of the wires. You can buy universal sensors and reuse your connectors. Too much trouble for me.
No good way to clean up sludge. However doing frequent oil changes with full synthetic oil (Mobile one for example) will clean the engine over time. Some people recommend Sea Foam. I have no experience with it.
Old 02-03-15, 04:25 PM
AndyM
AndyM's Avatar
Thanks! That helps!
What does the sticker look like/
What will it say if it is a California specification car?
Where is it exactly located under the hood?
UPDATE: I just looked under the hood everywhere. There are NO stickers except one on each side wall with the VIN.
UPDATE 2: I found out by reading Amazon reviews of the California specified sensor that you can determine if it is a California specification car by reading the VIN number. The fifth letter of the VIN will be "F" if it is a federal specification, and NOT a California one.
Old 02-04-15, 09:39 AM
tomf
tomf's Avatar
Originally Posted by AndyM
Thanks! That helps!
I think the 5th letter of the VIN is specific to the model year, make, and model. Why don't you just call a dealer with your VIN. They should be able to tell you.
I have a 99 ES300. This is what mine looks like. It's at the front of the hood looking up.
Emissions sticker on 99 ES300
Old 02-05-15, 04:49 PM
AndyM
AndyM's Avatar
Default Not a federal emissions car!
Got the sensors and it turns out that the car has California emissions. Not the federal emissions specification!
NOTE: There is NO STICKER under the hood. So the best way to find out what emissions standard you have is to look at the connectors on the front oxygen sensor and compare to Bosch website.
I found out when I tried to connect the wire. It has the wrong notches.
So to find out if you have the California or Federal emissions, look at the Denso site, it shows the notches, and then compare to your connector in the car.
Returning both to Amazon and getting the correct ones: Denso 234-9007 and 234-9009
Old 12-02-23, 03:24 PM
Herlexus12
Herlexus12's Avatar
Default Bank 1 sensor 1 connector pinout
1995 Lexus ES300 3.0 bank 1 sensor 1 the air fuel ratio sensor I need the pinout diagram for the connectors female and male the connectors got burnt up and I'm replacing them I need to know the schematic on The wire the color and position somebody give me the diagram for it please
Old 12-04-23, 03:00 PM
Pwrdude
Pwrdude's Avatar
You should be able to look at the one on the front of the engine (bank 2). The plugs and wiring will be the same on both banks.
AndyG
23
04-15-22 07:36 AM
LexusOwn15
04-10-21 02:27 AM
jaredmac11
10-15-19 09:40 PM
astroth
09-28-14 12:48 PM
imAC
04-17-13 07:19 PM
Quick Reply: where is "bank 1 sensor 1" on es300 1998 for a DIY job?
