RX 330 seat memory does not work.
Old 04-03-11, 06:39 PM
kuangmao
kuangmao's Avatar
Default RX 330 seat memory does not work.
Everytime I set the seat to a position,and press set then 1.(The position should saved in 1)
Next time when I press 1, but the seat is not set to the position where I setted.
whyyyy
Old 04-04-11, 08:24 AM
dcdyd
dcdyd's Avatar
I have similiar issue with my 08 350. I have set both postions. However when I turn on the engine, sometimes potion 1 works and some times position 2 works. If one position work, it will work for a couple of weeks.
I haven't really start diagnosing this issue. I am going to disconnect the negative of the battery for about 10 minutes and reconnect it to see whether this can be fixed or not. If it can't be fixed I will bring my car to the dealer. Buy the way, I have bad experience with the dealer and I don't go there if not absolutely necessary.
Old 04-04-11, 09:14 AM
01LEXPL
01LEXPL's Avatar
^^ Disconnecting the battery is what 'removes' the settings...
This is the case in many LExus'. My ES300 does it, my dad's '04 RX was the same story when we removed the battery and put it back in.
Old 04-04-11, 09:54 AM
Haunches
Haunches's Avatar
The vehicle has to be in park. Just covering everything.
Old 04-06-11, 06:56 PM
dcdyd
dcdyd's Avatar
I disconected battery today for 30 seconds. The driver memory position 2 still doesn't work. When I set the position I don't hear beep.
The positio1 works fine now. I wonder whether there is fuse only for position 2?
RichGag21
06-28-22 04:56 PM
matts6887
RX - 1st Gen (1999-2003)
16
11-17-14 08:19 AM
lexus114
07-19-08 07:07 PM
gebo
09-20-06 12:32 AM
Quick Reply: RX 330 seat memory does not work.
