Water Pump leaking
Old 05-27-14, 06:47 AM
  #151
VtotheJ
VtotheJ's Avatar
Originally Posted by Joe Z
^^ But how much ??
I set mine to Full (with cold motor).. Every 5,000 miles..
The fluid will have natural evaporation...
If there are no signs of leaking at the pump, top plate or mixed in your oil..
..I say your fine to lose a few ounces during a span of 3-6 months..
- Joe Z
Yup. No leaks here. I have to top off occasionally as well.
Old 05-27-14, 07:51 AM
  #152
PremiumG
PremiumG's Avatar
I had my oil changed at the stealer last Friday. No mention of a leaking water pump, I will check it today.
Old 05-27-14, 04:13 PM
  #153
J2K
J2K's Avatar
And another 08 water pump bites the dust. I mentioned a small amount of coolant loss to my service advisor and sure enough, the tech found that it was leaking.
Good news... it's covered under my platinum extended warranty.
Bad news... I got an IS250 as a loaner.
Old 05-28-14, 01:09 AM
  #154
I8ABMR
I8ABMR's Avatar
Originally Posted by J2K
And another 08 water pump bites the dust. I mentioned a small amount of coolant loss to my service advisor and sure enough, the tech found that it was leaking. Good news... it's covered under my platinum extended warranty. Bad news... I got an IS250 as a loaner.
Lol the 250 feels broken
Old 06-03-14, 08:17 PM
  #155
FNSSESPORT
FNSSESPORT's Avatar
Well, I got my car in March, just did my first oil change and what do I find?
Looks like another 2008 (66K kms) water pump bites the dust. Thanks to lobuxracer and 9aristo for posting some good replacement info, I'll definitely be doing this myself
Old 06-04-14, 01:54 AM
  #156
9aristo
9aristo's Avatar
yup mine leaked from the same spot. Very easy to do, took me 3-4 hours (being extra careful and paranoid as I baby the damn thing). After install, I checked for the next two days for leaks, so far so good (the gasket never looked trustworthy to me haha).
Old 06-04-14, 06:28 PM
  #157
FNSSESPORT
FNSSESPORT's Avatar
Good to know. One more question, what's space like? i.e. is it easy to get a torque wrench in there for the final torquing of the bolts holding the water pump? I'm a bit OCD when it comes to torque specs. Thanks again.
Old 06-04-14, 11:24 PM
  #158
9aristo
9aristo's Avatar
i had an extension and had no issues. I'd say if your extension + socket is less than 4 inches, you're good
Old 06-06-14, 08:46 AM
  #159
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,838 Likes on 2,327 Posts
The front of the engine is pretty easy to work on. When I did the tensioner, I didn't need anything exotic unless you consider a 6mm hex on a socket exotic.
Old 06-19-14, 02:03 PM
  #160
zen
zen's Avatar
add another in, 08 with 54k and just got the car. I took it to lexus dealer for inspection, and they found water pump leak and replace it under warranty.
Old 06-19-14, 06:07 PM
  #161
wmjeffreyw
wmjeffreyw's Avatar
And another 08 with 40k. PPE discovered while installing my headers. It looks like it has not leaked for a while but there is pink residue below the water pump.
Old 08-10-14, 01:47 PM
  #162
zojirushi
zojirushi's Avatar
The dreaded water pump leak rears it's ugly head again and rather inconveniently immediately after the warranty expires on my 08 42k IS-F.
Old 08-10-14, 04:02 PM
  #163
Reaper21
Reaper21's Avatar
I feel like mine should be leaking too but I haven't seen any evidence. It's an 08 with 70k on it. I had the front bumper off about a month ago to change the headlights, and I did the spark plugs about a week after that and both times I inspected and couldn't find anything.
Why hasn't there been a recall on this with so many being affected?
Old 08-10-14, 04:23 PM
  #164
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Originally Posted by Reaper21
...Why hasn't there been a recall on this with so many being affected?
Because not all of them fail, and not enough of them have failed with catastrophic results.
Old 09-01-14, 06:10 AM
  #165
FNSSESPORT
FNSSESPORT's Avatar
Shiny new water pump. I was amazed at how straightforward and easy the replacement procedure was. I found the hardest part was torquing the bolts for the pulley when putting it back on.Thanks again to lobuxracer and 9aristo for the very useful info they posted.
Quick Reply: Water Pump leaking
