Water Pump leaking
Old 05-17-11, 07:19 AM
CCColtsicehockey
CCColtsicehockey's Avatar
Glad to see this thread cause the dealer I had an oil change at during a trip last week told me my pump was leaking and I needed to get it replaced but they didn't have one instock and I was leaving the next day. Guess I need to look how bad mine is and get it scheduled soon.
Old 05-17-11, 09:32 AM
DemosISF
DemosISF's Avatar
ive been keeping an eye on my resevoir and its down past the low mark. checked the water pump sure enough pink crust formed on it.
Old 05-17-11, 02:52 PM
itsmike177
itsmike177's Avatar
Dropped the car off today and 3 hours later, dealer called to say it was ready.
Is the water pump on the ISF really 2-3 hour job to remove and install?
Part numbers on the invoice:
16100-39506 (water pump)
00272-SLLC2 (super long life coolant)
Dealership service manager stated that they had serviced another ISF with the exact same issue. Hopefully, this one will last more than 44k miles.....
Old 05-17-11, 03:10 PM
digger08
digger08's Avatar
My parts match yours except for the coolant number (Canada has some unique numbers). The book rate is 3.6 hours, I'm sure the tech's have it down faster than this though.
It is a pretty simple job as far as water pumps go.
Retail on this part is about $185 US and includes the gasket
Remove small inlet hoses, by-pass hose and lower rad hose - looks like 4 in total
Reverse to install.
Old 05-19-11, 12:36 PM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Lightbulb
Great Thread!!! Thanks for sharing...
I recently replaced my secondary fan blade & motor... I didn't notice and issues with water pump leakage..
I did a quck inspection last night in the areas shown and still didnt see any problems with dried fluid.
I'm going to try a take a closer look at both the air and drain holes soon..
Just to make sure there are no signs of problems.
My coolant bottle was sitting at "Low", so I also added about 6-8 ounces of the Toyota Long Life pink fluid.
Basically, to bring it right back to "Full"
(Make sure you check or adjust fluid on an over night cooled motor)
I guess its normal to lose about that much of fluid in over 2 years of operation and/or approx 35K miles...
Regards,
Joe Z
Old 05-19-11, 05:19 PM
gqisf
gqisf's Avatar
Well I checked mine last night and wouldn't you know it's leaking! I guess I'll put one on next week.
Old 05-19-11, 07:11 PM
itsmike177
itsmike177's Avatar
With all these reports of the water pump leaking in ISF's, and the water pump part number was changed for 2010, just wondering if anyone with 2010-2011 model years have the issue?
Old 05-19-11, 08:12 PM
Mitch08ISF
Mitch08ISF's Avatar
Sweet just checked mine looks like I'm in the clear for now! Not low on fluid and 0 drips anywhere on the block :-)
Old 05-19-11, 09:38 PM
Supraman16
Supraman16's Avatar
Give it time...I'm willing to bet most 08' F's are going to have to get the water pump replaced for premature failure.
Old 05-20-11, 07:15 AM
Civic Si-r
Civic Si-r's Avatar
Wow I am surprised the water pump has failed early. Some are saying 30K
Typically water pumps last until 75K or longer. It sounds like the 08-10 are affected and the 2011's have the newer version pump. Hopefully it will last until 75K
Old 05-20-11, 07:21 AM
7No
7No's Avatar
A buddy of mine just had the water pump replaced on his 2007 M3. $1500.
Old 05-20-11, 07:29 AM
Mitch08ISF
Mitch08ISF's Avatar
Well I know I'm one of the highest mileage on here about to hit 57,000 highway miles so I feel safe as of now. Plus I have pretty much modded all that I can not that that really matters.
Old 05-20-11, 09:15 AM
digger08
digger08's Avatar
I'm at 110 K which is about 69,000 miles in your old world American measurments.
Old 05-20-11, 09:28 AM
Mitch08ISF
Mitch08ISF's Avatar
WOW, well installation looks like cake so Ill worry about it when I see pink and low levels.
Old 05-20-11, 10:13 AM
Joe Z
Joe Z's Avatar
I wonder who manufacture's the Water Pump for Lexus ????
Can any of you guys that replaced, get a close look at the failed pump for stampings??
Seems to be some sort of random defect with the maker.
Especially if its leaking from the air and/or drain holes.
3 years is not a good life span for a pump... Should be lasting at least 90K miles...
(Under normal driving conditions )
Joe Z
Quick Reply: Water Pump leaking
