ES300 Trunk release button
Old 05-25-11, 09:46 PM
neojoneswd
neojoneswd's Avatar
Unhappy ES300 Trunk release button
I was hoping that someone has a fix when the glove box release button fails to open trunk? I cannot seem to figure out why?
I have a 1992 ES300.
Old 05-27-11, 05:37 AM
padavid12
padavid12's Avatar
The glove box button is not for opening the trunk. It is for disabling the trunk open button next to the gas cap button.
The following 2 users liked this post by padavid12:
Bill01568 (09-24-17), Ezroni (07-15-21)
Old 05-31-11, 11:08 PM
neojoneswd
neojoneswd's Avatar
Default Yikes! glove box button
thanks padavid12....i would have never guessed...do not have a manual as you might have guessed.
again, thanks
Neo
Old 06-01-11, 08:54 AM
ikant
ikant's Avatar
Seriously??!!--I didn't know this either!! All this time I've been racking my brain as to why the Trunk Release [on the door] just stopped working for no reason--figured it was a fuse. But now that Neo has brought it to the forums (before I did) and got an answer, I realize I've got a bunch of stuff jammed in the glove box...
Gonna take a look at it and see what happens.
Old 06-01-11, 09:09 AM
ikant
ikant's Avatar
UPDATE: Just went out and tried it, and it worked!! [LOL!!!]
Thanks Dave and Neo.
Old 06-02-11, 04:51 AM
padavid12
padavid12's Avatar
Not a problem. I had my glove box switch push by accident and did not know. I could not figure why my open trunk switch would not work. I check fuses over and over. I tried to trace the wiring. One day I opened the glove box and saw the switch. Flipped the switch and solved my problem. Of course that was six months later. Glad to help. David
Old 06-24-11, 04:47 PM
lexusfan05
lexusfan05's Avatar
I had the same issue, one day the trunk wouldn't open. I asked my kids why the heck it stopped working and they told me that there is a button inside glove box. Then I knew why it stopped working
Old 01-26-12, 01:31 PM
pacheco308
pacheco308's Avatar
Default es300 trunk release button
i pressed this button located in the glove box and my trunk still does not open could it be the switch itself that is broken.
Old 03-23-15, 08:12 AM
jjhutch98
jjhutch98's Avatar
Thanks padavid 12.... just inherited my 97 ES300 from my parents and they told me one of the "quirks" was the trunk could only be opened with the key. Well you helped me fix that within 24 hours of being the "new" owner.
Old 02-01-17, 04:02 PM
Boblee700
Boblee700's Avatar
My 99 doesn't work either even if the button in the glove box is in the correct position. I took the trunk/gas button area apart by the steering wheel and used a jumper wire to rule oUT the switch. Still nothing but when I did it to the gas lid it popped open. The truck release actuator isn't making any sounds at all. HELP!! I'm getting tired of having to turn car off to get in the trunk
Old 02-01-17, 05:01 PM
PFB
PFB's Avatar
You'll need to check the wires going to the trunk. They run along the left trunk hinge and are prone to break from the frequent opening and closing of the trunk.
Old 09-24-17, 09:43 AM
Bill01568
Bill01568's Avatar
We're just loading up the car for a trip. Trunk release worked flawlessly until it suddenly didn't. This thread was the first Google search result. BAM! All fixed! Wife and I both now know about the button! Thank you Internet! Thank you padavid12! (This car used to be my father-in-law's. We're still learning as occasional new thing about it.)
Old 11-14-21, 02:57 PM
Slyko
Slyko's Avatar
You guys are the BOMB!
Thank You.
Thank You.
Thank You.
mdfrith28
01-29-19 04:50 AM
velani
01-22-17 05:56 PM
Revived
05-25-16 01:11 PM
Leonard15
10-10-13 10:23 PM
business1s
06-03-10 08:07 PM
Quick Reply: ES300 Trunk release button
