Purchase - Oil filter housing
Old 08-15-11, 04:33 PM
Doubleg
Doubleg's Avatar
Default Purchase - Oil filter housing
Anyone know where I can purchase a oil filter housing for my 07 ls460? Im having a ton of problems getting it off and im afraid it will crack when I get to getting it off. Know the wrench/socket is slipping and it looks like the plastic is shot.
Old 08-16-11, 12:16 AM
Nick2JZ
Nick2JZ's Avatar
Check out this thread for the Aluminum oil filter housing from Toyota Venza V6.............. i am not sure this will work on our LS460.
http://www.tundrasolutions.com/forum...y/#post1544913
Old 08-16-11, 09:49 AM
G-SharK
G-SharK's Avatar
I got mine here a few years ago for about 16.00 - it looks like they are cheaper now. Goodluck
http://www.toolsource.com/toyota-lex...-p-100298.html
Old 08-16-11, 05:30 PM
Grisik
Grisik's Avatar
I could not find these caps anyplace. Anyone know a link or store that has them?
Old 08-16-11, 06:29 PM
Nick2JZ
Nick2JZ's Avatar
http://www.jowettengineering.net/
talk to Brian............................. come back and share info.
Old 08-22-11, 03:58 PM
Grisik
Grisik's Avatar
I emailed Brian at jowett engineering. He stated that he did not carry them any more since the cap is a own item. He gave me a part
number of 1562031060. I looked it up online and it cost about $25. He mentioned a larger housing that will fit the LS and let us use a larger filter for better protection. He is supposed to get me more details soon
Old 08-22-11, 04:50 PM
Nick2JZ
Nick2JZ's Avatar
Cool..........$25 for OEM Toyota aluminum oil fifter housing cheap. Please keep us update.
Old 08-22-11, 08:52 PM
jlawr
jlawr's Avatar
Check Sewell Parts.
http://lexus.sewellparts.com/oem-cat...S460-2008.html
Old 08-29-11, 05:55 AM
Doubleg
Doubleg's Avatar
That's great! Keep us inform. I think that would be a great option to those in need of changing out a stripped or cracked housing.
Old 08-29-11, 06:19 PM
Grisik
Grisik's Avatar
Brian is still working on it to make sure it will work. He has to measure some things and he's supposed to let me know.
Old 09-15-11, 01:24 PM
Grisik
Grisik's Avatar
I purchased the metal cover from Toyota this morning. It was $23.91. Oil filter was also only $3.76. I'll put it on thus weekend and see how it works.
Old 09-15-11, 03:42 PM
Silverpaws
Silverpaws's Avatar
Let us know and could you give us the part number if it works? Does it use the same filter as the LS OEM housing? Is it the same housing mentioned in Nick's post above?
Old 09-15-11, 05:18 PM
Grisik
Grisik's Avatar
Yes it is the same housing and uses the oem filter. The part number is 1562031060.
Old 09-16-11, 03:54 AM
Silverpaws
Silverpaws's Avatar
Thank you! Would like your opinions after the install.
Old 09-18-11, 04:05 PM
Grisik
Grisik's Avatar
Installed it today. No problems. The inside tube is a bit shorter. I ended up breaking the plastic one taking it off. Glad I had the new one to put on.
Quick Reply: Purchase - Oil filter housing
