IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
2001 IS300 - ABS on & TRAC OFF flashing
Old 08-29-11, 08:37 AM
LuxIS300
LuxIS300's Avatar
Default 2001 IS300 - ABS on & TRAC OFF flashing
2001 IS300 only 95k miles. Check engine light is on for P0440 - Evaporative Emission System. ABS light is on and TRAC OFF light is flashing. Do you know what exactly is going on here ? Anything is appreciated.
Things i have tried: I unplugged negative charge in battery. And re-attached it. Nothing. Un-attached the battery completely and let it sit for about 5 minutes. Re-attached it, all the issues are still there.
Old 08-29-11, 11:16 AM
anotherLS
anotherLS's Avatar
gas cap on tight? like a couple of turns, or you might have a bad 02 sensor
Old 08-29-11, 09:48 PM
LuxIS300
LuxIS300's Avatar
anotherLS. Thank you for the tip. Yes, gas cap is tight. I have had to get gas multiple times. Cleared the check engline light after fill up and it comes back on after like 30 miles or so. Lets say its a bad O2 sensor. Will replacing O2 sensor fix the ABS light that is on and the flashing TRAC OFF light ?
Old 08-29-11, 11:38 PM
isusu8o8
isusu8o8's Avatar
have you done any mods to your car?
Old 08-30-11, 05:35 AM
lookalike
lookalike's Avatar
i actually had a similar issue with my car back when it had like 60k miles. At that time it was luckily under warranty but the O2 sensor went out and i got the same ABS/TRAC lights blinking... anyway once the dealer replaced the O2 sensor the issue was gone. Doesn't make sense to me but apparently the cars computer freaks out when the O2 sensor goes out. which we all know is one of the few common issues with this car.
Old 08-30-11, 05:49 AM
LuxIS300
LuxIS300's Avatar
isusu8o8: Nope. No mods. Its fully stock.
lookalike: Thank you. It does makes since cause all of these issues started at the same time. In my case, I'm getting P0440 code. Evaporative Emission System. How do i know which O2 Sensor to replace ?
Old 10-01-11, 03:18 PM
jwrighteh
jwrighteh's Avatar
Default Flashing TRAC OFF and lit ABS warning
I have a 1998 ES300. I just had the rear struts replaced. When I started the car to drive away from the repair shop, the TRAC OFF light started flashing and the 'ABS' warning light came on. Could this be related to anything that might have ocurred while the struts were being replaced?
Old 10-01-11, 04:26 PM
dsouthmia0
dsouthmia0's Avatar
when ur check engine light comes on the track control light flashes to get ur attention. If the sensor is the problem then replacing it would get rid of all the lights.
jwrighteh get the codes read I'm not sure
Old 10-02-11, 07:59 AM
czum09
czum09's Avatar
Yea they might have stretched one of your abs sensors. That results in needing a new sensor. My car has had the lights flashing at me since I bought it lol
Old 10-02-11, 10:08 AM
dedott21
dedott21's Avatar
I had the same problem 2 weeks ago being in a rush,I forgot to tightened the gas cap but i replaced the gas cap but didn't throw the old one away! once i did the the ecu resest(unplug the negative bat cable) for 5 mins and place the battery cable back on and no more codes! i suggest you keep your oem gas cap because when I bought the new cap and I threw the same code(p0440), I replaced the new one with the old one and I've never had any problem since!
Old 10-02-11, 10:24 AM
is350memb
is350memb's Avatar
o2 sensor bro. check it
Old 10-02-11, 07:33 PM
voleduy
voleduy's Avatar
I had the same issue with my IS. Usually with the TRAC light flashing, there're some unplugged or not completely plugged connectors. Did those lights come up after you've done something with your car. If yes, then check all the connectors that you worked on to insure they are plugged in.
Wait for the update.
Old 11-02-11, 12:54 PM
rxver
rxver's Avatar
Default TRAC lights flashing and Check engine lights ON
I have 2001 IS 300 and I got that check engine lights ON and TRAC lights flashing at the same time my APPS went bad... but after replacing my APPS it went out... NO CLUE why???
Old 10-19-14, 10:04 PM
linzetta93
linzetta93's Avatar
Default is300 ABS/Trackion control light
I put lowerings on thr front of my lexus. Then when i.turned the car in the ABS & trackion control light is on. Is something not hooked back up right? It didnt have any lights on before.
Old 10-20-14, 07:40 AM
Scratchy
Scratchy's Avatar
most likely unplugged or broke an ABS sensor.
jump these 2 pins on your obd2 plug:
check the service manual for the codes. it can be found as a pdf online. should narrow it down to which wheel(s) is causing the trouble code.
or you can just go brute force, and check the ABS sensor on each corner.
Quick Reply: 2001 IS300 - ABS on & TRAC OFF flashing
