Removing rubbing compound scratches?
Old 09-26-02, 03:08 AM
mjr24
mjr24's Avatar
Default How to remove scratches caused by rubbing compound?
I pressed the rag with rubbing compound on it too hard on the finish of my black SC and now there is a ton of fine scratches as a result of the compound. I cannot feel them with my nail...so they didnt get to primer.
What can I use to remove them?
Old 09-26-02, 07:15 PM
bravo261
bravo261's Avatar
what rubbing compound are you using? pressing the towel too hard won't do all that scratching by itself. i'm guessing you need to rub the compound some more until it breaks itself down further. if that doesn't work, get a foam applicator, which is just about $2 at any auto store. and remember to rub it in very good
Old 09-26-02, 07:21 PM
mjr24
mjr24's Avatar
I think it is the 3M Fine Cut Rubbing Compound.
Old 09-26-02, 07:58 PM
bravo261
bravo261's Avatar
that one is for big scratches and pretty abrasive. its best to use FCRC and follow with their 3m SMR. a two-step process really. the swirl mark remover is made for, well, swirls, and yours if for scratches.
so you reduced the scratches to a million swirls like you should have, so now just polish off the swirls. you're half-way to a perfect finish
Old 09-26-02, 09:40 PM
Daddy-O
Daddy-O's Avatar
What you have to do is replace the larger scratches made with the compound, with smaller and finer scratches until they're no longer visible.
I recommend 3M Swirl Mark remover for dark finishes.
Work it goood! Until it is dried and hazy...Wipe off excess with a clean all cotton towel or quality microfiber towel. Examine your work from all angles. Repeat as needed.
Then use Meguiar's ScratchX...
You can use rubbing alcohol, on a clean, all-cotton towel, to remove fillers/oils that are in these products so you can see your real progress.
I use terry applicators, as foam pads can produce a truly
irritating, nasty squeaking sound as you're working the polish in.
Wash your car good, then finish with:
3M Imperial Hand Glaze or Meguiar's #7 Show Car Glaze.
Then. finally wax to seal. Done!
Good luck.
Old 09-27-02, 03:40 AM
mjr24
mjr24's Avatar
See I had to glue my front emblem back on....the nose was repainted 2 weeks ago...so there was 0 scratches. Anyways, some of the glue got on the hood and I rubbed the compound too hard....it got rid of the glue...but left a ton of scratches that werent there before.
Yes, it likely was too abrasive. But you are saying these can be taking out by using a swirl remover and then scratch x?
Old 09-27-02, 03:43 AM
mjr24
mjr24's Avatar
Another thing Im worried about is paint guy said no polishes or wax for 30 days after paint.
So I shouldnt have used that compound....so should I wait til I hit 30 days to use the scratch X and swirl remover?
Old 09-27-02, 04:15 AM
bravo261
bravo261's Avatar
sure, just go ahead and wait then.
paddy, that left nothing to the imagination!!
Old 10-19-02, 09:13 PM
mjr24
mjr24's Avatar
Was thinking about this more as it has now been 30 days since the bodywork so I am free to polish the area.....but I forgot to mention my front nose is plastic. These scratches arent your swirl marks that you can see at only some angles....these are scratches you can see from any angle.
Old 10-20-02, 01:02 PM
Daddy-O
Daddy-O's Avatar
Go ahead and try the method I recommended. Don't try to do it all in one shot. Remember, what you're doing is replacing the larger scratches made with the compound, with smaller and finer scratches until they're no longer visible.
Take your time. It'll work out.
96SC4
07-29-14 08:11 PM
tmf2004
16
06-22-07 09:08 AM
G Star
07-31-04 03:29 PM
Baby ///M3
12-05-03 11:43 AM
dirtymarti
07-22-03 04:49 AM
Quick Reply: Removing rubbing compound scratches?
