Key Remote ROM location
Old 10-15-11, 07:01 PM
KahnBB6
KahnBB6's Avatar
Received 1,221 Likes on 856 Posts
Thank you for this writeup. If only it had appeared last year I could have saved myself $200 by having a Lexus dealer do this for me. There was no information on how to install this at the time :/
So... no other procedure to code the keys using sequenced locking/unlocking of the doors as with later model SC's?
Old 10-16-11, 09:52 AM
Zeke21
Zeke21's Avatar
I believe the programmable keys began in 95 but it might also be 96. I'm not 100% sure. Someone on here might know.
Correct. With the 92-94 models (possible 95) key chips are not programmable. The chip in the keys are only designed to work with the ROM located in the car. If you lost your keyless entry due to bad chips in a key or the ROM went bad You'll have to buy a key set (Key and ROM together) in order to get the keyless entry working again. I've also read other issues with the keyless entry atenna on both the keys and in the car. One might want to make sure that is not there issue before spending the money on a new key set.
Old 11-01-11, 08:57 AM
TougeSC3
TougeSC3's Avatar
This is beyond fantastic. My master is beat up and just sits at home. It's rough. My valet is rough too. I can atleast put it on my keys. Thanks for the write up. I'm going to tackle this soon.
Old 11-01-11, 09:22 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
We explored the rom and more in 2006 which may save people from having to replace the system https://www.clublexus.com/forums/sc-...ess-entry.html
Old 11-01-11, 09:32 AM
TougeSC3
TougeSC3's Avatar
I remember that thread B. My keys are busted and I need some new hotness.
Old 11-01-11, 12:16 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
I do too, but she ain't here........
Old 11-01-11, 12:21 PM
TougeSC3
TougeSC3's Avatar
Lololololol
Old 11-02-11, 08:02 AM
horent135
horent135's Avatar
I know this guide is for older SC, anything for like 98-00 SC? My keyless remote is dying, i change the battery twice, still no light or flashes 1 time real quick, but it does not perform lock/unlock my door. Car can start fine.
Old 02-26-12, 02:57 PM
jayclapp
jayclapp's Avatar
I just completed installing the chip for a new set of remote keys for my 02 SC400. Would never have attempted that without the excellent photo tutorial. I have the following comments:
It is necessary to remove the rear seat backs in order to remove the side panel. However, that is not difficult as you only have to remove 3 bolts and lift it out.
I couldn't get the new chip to slide into place. It is a blind installation regarding the pins and the pin slots. No amount of trials and jiggling around would work. I could easily remove and reinstall the old one. I finally resorted to disassembling the box itself. That was accomplished by bending up 4 tabs which then allowed the top to be removed. With it open, I could then see the pins and the pin slots on the chip. I finally found that if by pushing down on the chip in the area of the pin slots that it would engage and slide into place.
That was kind of scary, but actually quite easy. Installed the box, connected the antenna and electrical connection and everything worked as advertised!
I purchased the keys from Sewell and had them cut the keys to my VIN number.
Again, thanks for excellent instructions on a subject that was rather difficult to find.
Old 02-27-12, 12:19 PM
tj4306
tj4306's Avatar
I know that this is off topic, but can you use a 1996 key with the transponder built in on a 1997 sc400?
Old 04-15-12, 08:16 AM
Zeke21
Zeke21's Avatar
You're welcome - glad it helped someone out. Yes it took me a little while to get the new ROM into the ECU...it felt like it didnt want to go in all the way. Eventually I pushed in a little harder and it went in. But it did make me nervous. lol.
Old 04-16-12, 06:25 AM
harrisep
harrisep's Avatar
Thumbs up Replacement Key/Remote
If you need a replacement key/remote, search ebay for the seller "remote.overstock". Excellant customer service and products. Wayyyyyyy cheaper than going to the dealer. See link below.
http://stores.ebay.com/Remote-Overstock
Old 04-16-12, 06:35 AM
Zeke21
Zeke21's Avatar
Originally Posted by harrisep
If you need a replacement key/remote, search ebay for the seller "remoteoverstock". Excellant customer service and products. Wayyyyyyy cheaper than going to the dealer.
I have rarely seen the style of key I've written this DIY for. You are likely talking about the 3 button key which is found very often on ebay. The single button key is not too often found on ebay as a blank.
Old 04-16-12, 07:43 AM
jayclapp
jayclapp's Avatar
Just looked at ebay. Their keys are all non-transponder blanks that will work in the ignition, but no remote capability as that requires a new chip for the receiver. Those are priced at less than $20.
There was one ad with a used, already cut, key which has a remote button for $99. That key is entirely useless and would not work in any form or fashion.
One has to know what they are doing before just buying a key that is offered on ebay.
Old 04-17-12, 01:34 AM
Devor
Devor's Avatar
couple questions here.
How much does the chip that goes in your Box for the keyless entry cost? Can you use any one or does lexus have a designed chip made for your exact car that you have to buy direct from them?
I have an aftermarket radio so I can not tune into the radio at to see if I get the signal from the keyless entry.(TEST KEYS SIGNAL) Nor do I know if My (RADIO)antenna is even hooked up does that signal correspond with the keyless entry signal?
Quick Reply: Key Remote ROM location
