Squeaky suspension and groaning/grinding brakes
Old 09-18-11, 07:41 AM
richard198
richard198's Avatar
Default Squeaky suspension and groaning/grinding brakes
I have a 2008 IS-250. My front left suspension area squeaks when air temp is low and the vehicle is going over bumps. Adding air pressure to the front left tire seems to reduce squeaking, as does increasing air temp. So my guess is the lower air pressure is changing the way weight is distributed through the suspension, which is causing the squeaking. It only occurs on the front left.
Additionally, front left brake is groaning/grinding while doing light braking at extremely low speeds (such as rolling with brake applied). Braking while turning hard (such as pulling into or backing out of a straight parking spot) creates the groaning noise as well as a cracking noise. When releasing from a full stop, there is a noticeable but quiet cracking/popping noise. Like the squeaking, this only occurs for the front left and seems to be affected by the air pressure in the tire.
Any idea what should be done to fix this?
Old 09-18-11, 08:36 AM
Gville350
Gville350's Avatar
Check your brake pads. Beware, like in my case the inner pad wore down more quickly that the outer pad...I had similar scratching sounds at low speeds, but mainly when turning left.
nomz09
RC - 1st Gen (2015-present)
10-25-18 01:16 PM
daryll40
04-07-14 04:31 AM
mann777
GX - 1st Gen (2004-2009)
15
03-27-09 11:08 AM
teracon
07-12-06 02:16 PM
Nostics_RX
05-26-06 05:28 PM
Quick Reply: Squeaky suspension and groaning/grinding brakes
