anyone have experience with dead battery then check VSC and check system light on?
Old 10-02-11, 07:52 PM
kim0217
kim0217's Avatar
Default anyone have experience with dead battery then check VSC and check system light on?
My battery die today, I start the engine again, then the check VSC, system lights on... anyone know whats goin on?
Old 10-02-11, 09:13 PM
shadowman
shadowman's Avatar
Is the warning lights still on? Perhaps, it's the ECU trying to re-learn your mods such as intake. If the battery died completely, the ECU may have reset back to factory default.
A similar situation to a dead battery happen to me, I disconnected my battery while I installed the my intake. I hooked up everything and restarted my car. CEL, VSC light came on and then my engine stalled. But it restarted fine after learning the new air ratio.
Is the CEL lights on? If yes, perhaps you can go to autozone and have the error codes pulled. Then google them or post them up so the gurus here can have an idea.
Old 10-03-11, 07:39 AM
calvin2376
calvin2376's Avatar
You need to provide much more information for anyone to help you.
Your battery died. Then what did you do? Jump it, or get a new battery? What had you done recently, any mods, etc? Then you started up the car and got warning lights. You need to check the error codes with an OBDII scanner or stop by an Autozone or similar and post the codes here.
Old 10-03-11, 12:30 PM
lexi487
lexi487's Avatar
i ran into the same problem few weeks ago
i had gotten my car started after a jumpstart but my check VSC light came on also my traction light wouldnt go off
i called lexus they asked me to bring it in - but the nearest lexus dealer is 80 miles from me and the toyota dealer wouldnt help so i drove it around for about 10/15 mins parked it and when i started it back up again they all went away and havent had a problem since im assuming cuz my batt was so low it threw the system off and reset everything but if yours are still on i suggest you take it in
bakehot82 (08-02-20)
Old 10-07-11, 06:10 AM
laoreflxzn
laoreflxzn's Avatar
Well I had a similar issue. I changed to a new battery, VSC comes on when I put into gear and car moves a few inches. I tried the Zero calibration reset didnt work for me. So I decided to bring it to Lexus, told them to tell me what it is before doing anything. When I went to pick up my car the service guy told me they had to recalibrate some steering sensor or something like that and had to do the Zero Point Calibration, which took them probably 10 mins to do. Gave me an invoice for 119...smh.
Old 10-07-11, 10:00 AM
JEFFOS69
JEFFOS69's Avatar
I would just drive on I or a bit since the car drives normally. The computer checks all sensors periodically and when driving at temp for a certain time. I bet after a couple of days of driving it will all reset to off.
Old 01-10-13, 05:43 PM
DCQUEEN07
DCQUEEN07's Avatar
I ran into the same problem today. Car wouldn't start when I came out the gym. Before that I sat in the car charging my phone with the engine off and the lights flickered a bit. I figured it was the battery so I had it jump started with cables. Car started fine except now there is a check engine light. Vcs light the error exclamation light and traction light on. Anybody know what this could be?
Old 04-17-13, 01:44 PM
TLRD
TLRD's Avatar
I had this issue today.. Anyone ever figure this ish out?
Old 05-26-13, 02:12 PM
redmethods
redmethods's Avatar
Anyone have a fix for this yet? No codes can up for this on my OB2 scanner.
Old 05-26-13, 03:58 PM
lysis250
lysis250's Avatar
Unplug your ground from battery for around 5 minutes and it should do the trick.
Old 06-25-13, 06:56 PM
redmethods
redmethods's Avatar
No it is still on. And one else?
Old 06-25-13, 11:40 PM
IS25Heaven
IS25Heaven's Avatar
Had this issue for a week or so, and I knew the battery was dead. Drove it until the car wouldnt start anymore. Once I replaced the battery it went away. My car is an 08, so it was time to change the battery. Take it to an o'riekeys or autozone and have them check the voltage on the battery. Maybe your cells might be dead.
Old 06-26-13, 12:27 AM
laziepig
laziepig's Avatar
Weird.. it should work fine after a battery replacement which I did yesterday.. no warnings lights on..
Old 06-13-15, 07:35 PM
sthakor92
sthakor92's Avatar
Same thing happened to me today. My dad drove my car, then it wouldn't start so we jumped the battery and now the check engine and traction control light are on... I disconnected the battery and it removed the lights for the time being but I'm wondering if anyone else realized anything awry?
Old 06-13-15, 08:22 PM
flowrider
flowrider's Avatar
Received 1,815 Likes on 1,281 Posts
^^^^Here:
https://www.clublexus.com/forums/is-...-of-codes.html
Lou
Quick Reply: anyone have experience with dead battery then check VSC and check system light on?
