check engine/ trac off light are on
Old 10-18-11, 02:44 PM
mosquju70
mosquju70's Avatar
Default check engine/ trac off light are on
What is the fix to this issue on a 2001 es 300
Old 10-18-11, 03:02 PM
01LEXPL
01LEXPL's Avatar
did it occur to you to drive down to autozone to get the codes scanned?
Old 11-06-11, 05:34 PM
pronkie1
pronkie1's Avatar
Just went through this with my step son's 2000 ES 300.....Twice in two months....Was 02 sensors on the exhaust manifolds each time.....He only has 66k on it.....
Old 11-06-11, 06:54 PM
yeldogt
yeldogt's Avatar
lots of things can cause this.
And as the sensors age the heaters inside the fail -- so it is not simply a mater of the miles.
Old 11-08-11, 04:09 PM
Amadauss
Amadauss's Avatar
I have the same issue and the code is stating P0420 which is the bank1 02 sensor which is the one under the drivers seat from what I am told. Got the sensor and now need to replace but have heard various about location of it. Told to check out a post in the RX section that talks about taking the drivers seat out to make the change. Is this correct? Thanks.
Jordan95
01-22-18 07:23 PM
gomboy60
05-18-11 01:32 PM
Mylesf7
11-13-08 05:16 PM
royaladd
RX - 1st Gen (1999-2003)
15
11-05-08 11:48 AM
LEX300AM
12
11-03-08 07:28 AM
Quick Reply: check engine/ trac off light are on
