Heated Seat Switch Backlight
Old 10-19-11, 06:44 PM
hoonami
hoonami's Avatar
Default Heated Seat Switch Backlight
I was driving home one night and noticed that my heated seat switch backlight went out, anyone know how to fix this? do i just pull the switch out? is it replaceable bulb?
Old 10-19-11, 10:01 PM
ac921ol
ac921ol's Avatar
insure its something you can change, pop up the gear shift panel (wood) and pull out the heated seat and headlight washer panel (Wood) and check to see if you see a bulb or led or wah not
Old 10-20-11, 06:13 AM
shoebopper
shoebopper's Avatar
On my '06 RX330, this is listed as a part...
Seat heater switch bulb with cap...p/n #90011-01046...discount about $3.60; full price $4 - $6. Should be available through both Toyota and Lexus dealers.
I noticed that I have the same problem and am curious about how difficult it will be to replace. Expensive for a 1.12 watt bulb!
Last edited by shoebopper; 10-25-11 at 06:43 AM. Reason: Because my brain and fingers do not operate at the same speed.
Old 10-20-11, 10:01 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
I'd go for LED....
Old 10-21-11, 02:50 AM
nwfsnake
nwfsnake's Avatar
Here are pics I took. You will need to remove the panel, as the switch is held in top and bottom by two taps. I used a small flat screwdriver to release them. The light is on top. You could use the Radio Shack # 7219 replacement bulb on it for a cheap fix but it will glow yellow instead of green. The stock bulb is larger, also, but I have use the RS bulb in the past in these applications and it works fine.
Attached Thumbnails Heated Seat Switch Backlight-rx350_seat_heater_switch_b.jpg   Heated Seat Switch Backlight-rx350_seat_heater_light_a.jpg
Old 10-21-11, 10:07 AM
jamodeo
jamodeo's Avatar
Isn't that green "condom" removable? It was on my GS and I have never looked at the bulbs on my RX so couldnt you just take the green condom off and put it on the new bulb so it will light up green?
-Joe
Old 10-21-11, 10:14 AM
hoonami
hoonami's Avatar
i just took mine out, and ordered the bulb from sewell.
and yes that green rubber cap is removable. after replacing it i will keep you guys posted with a result.
Old 10-24-11, 05:32 AM
shoebopper
shoebopper's Avatar
nwfsnake:
How did you get the panel off? Just curious.
hoonami:
Let us know what you had to pay for the bulb, w/ shipping. Curious about that too!
Old 10-24-11, 06:00 AM
nwfsnake
nwfsnake's Avatar
I cheated, this is a panel I purchased from ebay. I am going to install seat heaters, and wanted the factory switch. It has two press in clips, one on each end. One of those nylon pry tools should do the trick.
Old 10-24-11, 11:01 AM
ac921ol
ac921ol's Avatar
here is how you can take the panel out, not a complete DIY but to give you guys an idea on how to get in there and see whats going on.
(thanks carver)
Old 10-24-11, 11:13 AM
MC5Wes
Registered User
MC5Wes's Avatar
Default Panel
It is very easy to remove the switch panels.
Push your center console all the way back.
On the aft bottom edge of the gear shifter lift up.
Remove trim from around gear shifter.
On the bottom edge of the cigarette light panel pull aft.
Disconnect the wiring.
Old 10-24-11, 04:47 PM
hoonami
hoonami's Avatar
Originally Posted by shoebopper
nwfsnake:
hoonami:
i bought a bulb and wiper refill set from sewell. bulb was $4 but if you are only ordering a bulb you might as well visit your local dealer. minimum shipping isn't worth it. or you can visit your toyota dealership with a bulb if you have it taken apart.
Old 10-25-11, 03:46 AM
nwfsnake
nwfsnake's Avatar
I wonder how much the bulb is from just a Toyota dealer? Half the price of the Lexus dealer? Honda/Acura uses these same bulbs and sockets, maybe I will check their price and post it.
Old 10-25-11, 06:44 AM
shoebopper
shoebopper's Avatar
ac921ol: I don't know about anyone else, but I couldn't view the picture/diagram you added. Could you post it again as a PDF or something? Thanks.
Old 10-25-11, 06:58 AM
RX330inFL
RX330inFL's Avatar
It is a video on YouTube. Comes through fine here.
Quick Reply: Heated Seat Switch Backlight
