Old 01-07-15, 04:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
power window switches do not work properly
Old 10-22-11, 08:11 PM
kuangmao
kuangmao's Avatar
Default power window switches do not work properly
Usually the driver side has all 4 windows switch can control all the windows up and down.
And to lower the window, push the switch halfway down, or push to switch all the way down to fully lower the windows(the window comes down automatically).
But after replace my battery,window switches do not work properly.
The driver side switches can not control other 3 windows, And push the switch fully down. the window won't comes down automatically
What is the problems?
Thank you
Old 10-22-11, 08:18 PM
Carver
Carver's Avatar
After you install a new battery you will have to reset the windows, moonroof and the deck lid (maybe), It is explained in your owners manual.
Old 10-22-11, 08:45 PM
RX330inFL
RX330inFL's Avatar
Told you on your other thread that you needed to read the manual about how to reset the window controls after changing out the battery:
Originally Posted by RX330inFL
Simple... batteries go bad. Get yours replaced. Advance Auto, AutoZone, Sam's Club, etc. If under warranty then talk to your dealer.
Afterwards, check your Owner's Manual about how to reset your window controls.
Those headlights draw a lot more power than the radio does -- 55W @ 12V (each) if I remember correct. Probably why you had no problems with just the radio on.
Old 10-22-11, 10:22 PM
kuangmao
kuangmao's Avatar
the manual does not have anything about reset windows.says"Contact Lexus Dealer"
But I just figured out my self.(hold the window switches on every side for 10sec)
Thanks guys
Old 10-23-11, 06:32 AM
jfelbab
jfelbab's Avatar
You will also need to reset your sunroof. Depress and hold the tilt button until the roof tilts up, tilts closed, slides open and slides closed. Then i/release the button and t will be reset. If your rear hatch doesn't seem to operate correctly just open and close it manually to reset it.
Old 10-23-11, 09:00 AM
RX330inFL
RX330inFL's Avatar
Thanks guys
From the Owner's Manual page 694:
If the battery is disconnected or run down
The following functions may not operate correctly when you
reconnect or replace the battery. In these cases, you should
do the each instructions referring on the following pages.
 Power back door (See page 46.)
 Power windows (See page 74.)
 Moon roof (See page 148 or 152.)
Old 10-23-11, 10:12 AM
Rainbird
Rainbird's Avatar
A simple search of this forum would have answered this question as well. It has been asked and answered many times.
Cobra611
08-10-18 09:05 AM
momof1
09-12-17 04:41 PM
kevenhang
02-24-16 09:43 AM
Quick Reply: power window switches do not work properly
