1305 code
Old 10-30-11, 12:38 AM
mr858
mr858's Avatar
Default 1305 code
Had timing belt changed and now keep getting DTC 1305. Changed igniter and it still occurs. Any suggestions?
Old 10-30-11, 12:39 AM
mr858
mr858's Avatar
96ls400...car keeps cutting off
Old 10-30-11, 01:16 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
P1305? you probably cut a wire between the ignitor and the coil. check the harness especially near the covers for the timing belts/distributors.
Old 10-30-11, 02:48 AM
steve2006
steve2006's Avatar
Check particularly around the crank shaft position sensor wiring, it's fairly easy around there to not redress the wiring loom correctly and get the wires damaged.
Old 10-31-11, 09:27 AM
AussieAuto
AussieAuto's Avatar
I have changed cam position sensors for that code, 1 from damage to wiring when someone did a t/belt and another was just a bad sensor with 425k on it...
Old 10-31-11, 11:42 AM
imspencer
imspencer's Avatar
Good advice with checking wires to a from coil. As I just bought a '96 and just did the TB/WP. Mine started giving me the same code and I found the bottom clips to the coil had cracked and plug was loose and not making good contact. enjoy, =spence
GARYWLTN
08-17-15 12:44 PM
Jdmsc5spd
Performance & Maintenance
04-27-13 02:12 PM
NSeagle78
07-07-11 04:49 PM
LiCelsior
29
03-04-09 10:07 PM
fju2112
10-02-08 12:52 PM
Quick Reply: 1305 code
