IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
IS300 2JZ-GE -GTE swap?
Old 11-12-11, 08:39 PM
LucciLou
LucciLou's Avatar
Exclamation IS300 2JZ-GE -GTE swap?
what exactly will i need besides a GTE head when i do the swap i have an 01 is300..should i keep the stock diff i wanna be able to drift..i need a tranny swap as well....its an auto right now...is a GE bottom end strong eventually i wanna boost?
Old 11-12-11, 10:24 PM
tjmhillz
tjmhillz's Avatar
Ive seen people drift with just an 5spd n/a IS. As far as your questions. You can keep the stock GE head and just use the GTE bottom end or just use then internals from the GTE. You should also use the TT headgasket and while your at it might as well get some arp headstuds.
As far as swapping out trannys. you will need the following parts
5spd tranny
shifter
Slave cylinder
Clutch Pedal
neutral saftey switch
cruise control clutch switch
Clutch master cylinder
Clutch Line
Shift boot
Flywheel
Manual brake pedal
Manual drive shaft
Rear engine “transmission” mount
Stock Shift ****
Transmission cross member
New pressure plate & clutch disk
M/T Ecu
Good luck
Old 11-18-11, 08:46 AM
Jerm23
Jerm23's Avatar
to start drifting all you need is some basic suspension mods like coilovers/sways and an LSD. then you start building your own turbo kit.
Old 11-19-11, 10:37 AM
LucciLou
LucciLou's Avatar
Default ?
5spd tranny
shifter
Slave cylinder
Clutch Pedal
Clutch Line
Shift boot
Flywheel
Manual brake pedal
Manual drive shaft
Stock Shift ****
M/T Ecu
Good luck
Thx Warrior appreciate it! i thought people be swappin out there GE head for a GTE head? they mainly are just using a GTE bottom end?
Old 11-19-11, 10:39 AM
LucciLou
LucciLou's Avatar
Default Turbo
when building your own turbo kit how do you know how to go about it? how do you know exactly which turbo to get n all that...?
Old 11-19-11, 04:05 PM
czum09
czum09's Avatar
I vote you do suspension first. Upgrade the sways and lower it. Getting this car sideways without the proper suspension is pretty sketchy. The car is tuned out of the factory for under steer. Just my .02
Old 11-19-11, 04:42 PM
dsouthmia0
dsouthmia0's Avatar
Reading Reading and more Reading other peoples build threads
Old 11-19-11, 08:03 PM
baadhabit
baadhabit's Avatar
if you dont know where to start then maybe you should look at some the proven NA-T kits put out by SRT
www.swiftracing.com/
Old 11-20-11, 08:31 AM
Turbocivic
Turbocivic's Avatar
I would buy SRT kit or used one off someone. Building a good kit still cost as much as SRT.
Old 11-30-11, 03:20 PM
LucciLou
LucciLou's Avatar
Arrow more then .02
your exactly right its sketch as hail w/o suspension! so get lowering springs and sways then front and back?
Old 12-01-11, 05:03 AM
FOOBER2
FOOBER2's Avatar
If you're drifting, you're probably going to want a nice set of coilovers. It's likely that springs won't be stiff enough.
Old 12-01-11, 05:20 AM
dsouthmia0
dsouthmia0's Avatar
I just built my own turbo kit, Ill share what I am doing just to give you an idea. Started with a barely used Turbonetics kit that came with turbo, intercooler with piping, header/manifold, and I start piecing from there. My set up will be good for atleast 4-500 hp
Engine
$3000 turbonetics kit with intercooler, manifold, piping,
$600 custom bent 3" exhaust
$500 GTE rods/pistons
$100 new piston rings
$350 Solid motor mounts
$150 GTE head gasket
$250 Engine gasket kit
$120 engine bearings
$400 LS400 throttle body
$150 ARP rod bolts
$200 pulley kit
Transmission
$900 R154 Tranny out of MK3 Supra
$300 2JZ bellhousing so tranny fits your motor
$700 ACT clutch kit
$500 Single piece drive shaft
$300 short shifter
$250 Shifter Modification
$50 speed sensor
Electronics
$1000 Greddy Emanage Ultimate ECU with plug N play harness and map sensors
$700 AEM boost, wideband, oil pressure gauges
$100 Greddy turbo timer
$500 HKS DLI
Im sure I'm missing a few things but its mostly all their. Im real close to starting my build, motors already out
Old 12-01-11, 11:16 AM
LucciLou
LucciLou's Avatar
Question Hmmm
i just got the ToKico HP Blues will that sways and springs be stiff enough u think?
Old 12-01-11, 11:21 AM
LucciLou
LucciLou's Avatar
Arrow Nice
Engine
$150 ARP rod bolts
$200 pulley kit
Transmission
$700 ACT clutch kit
$300 short shifter
$50 speed sensor
Electronics
$500 HKS DLI
where do you find GTE parts at? & how do you know which GTE parts or other Lexus parts from other cars will fit on the car? i like that LS400 throttle body....where did u get a supra tranny from? what bottom end do you got? i heard GE bottom end is weak so to swap it wit a GTE...?
Old 12-01-11, 11:26 AM
1100HP
1100HP's Avatar
You heard wrong my friend. Most big boy Supras use the GE bottom end in their build. They can handle the exact same amount of power.
Quick Reply: IS300 2JZ-GE -GTE swap?
