Highway wandering
Old 06-04-14, 02:12 PM
  #136
TSA1
TSA1's Avatar
Someone in an another thread mentioned that their wandering was caused by "rear A- arm bushings" but I cannot find these bushings part number. Is it the entire A-arm that must be replaced or could he have meant the control arm bushings?
My car still wanders lol
Old 06-04-14, 02:19 PM
  #137
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
they are available as aftermarket replacements through some companies, through others, the whole arm must be replaced...
Old 06-04-14, 02:28 PM
  #138
Lavrishevo
Lavrishevo's Avatar
Lower control arm bushings are probably what is meant.
Old 06-04-14, 03:20 PM
  #139
Pamperme
Pamperme's Avatar
Originally Posted by Stu
The story continues .... Some of you will recall that my LS wouldn't drive straight without wandering all over the road. I replaced my 18" wheels, got 3 sets of new tires, had 4 wheel alignments and replaced the steering bushings and while the car drove a bit better, it still was not satisfactory. The car reached 90,000 miles and the wandering remained. I drove the car but my enjoyment was diminished.
Took it an hour outside the city to a guy who sets up Time Attack race cars to see if he could find the problem and he checked every single item you guys identified. He went over the entire suspension and reported everything was fine. He did a 4 wheel alignment and said the rear was just barely in spec .... and he was able to adjust it. (The rear camber was, as all of you said, was not that bad ) He concluded that if the alignment didn't fix it completely he would look at the variable speed assisted power steering unit ( I think he said it runs on a vacuum ) if I was able to locate the "variable speed power steering diagnostics"
The car drove well on the way home and I will be absolutely amazed if it does not need to go back to him in the spring to fix the variable speed assisted power steering unit. Time will tell. But .... if all it needed all this time was a competent alignment .... and all 3 prior alignments were bad, I may have to break a few faces, lol
Can anyone tell me where I can find the "variable speed power steering diagnostics". I would like to print it out so I can bring it to him IF needed
This story may actually have a happy ending
Since 2011 when u first posted the issue, u never took it to the dealer to have them align it? Only third party repair shops?
Old 06-04-14, 04:59 PM
  #140
Stu
Stu's Avatar
Yes, I took the car to my local Lexus dealer, Lexus on the Park, which happens to be their flagship store in Toronto. In retrospect, their advise was just an attempt to make themselves money ....
They put the car on the alignment rack and told me the rear camber was out of spec, and the aftermarket wheels should be replaced with OEM wheels. They quoted me $1,500 to get the rear camber into alignment and another $1,600 for OEM wheels. After this was done THEN, if the wandering was not solved, they would start to diagnose the wandering issue.
In the end, the car just needed a proper alignment, which I had a lot of trouble getting, even from a Lexus dealer !!!!
By the way the car drives perfect now
Old 06-04-14, 05:09 PM
  #141
Pamperme
Pamperme's Avatar
So glad it all worked out for u in the end!!
Old 06-12-14, 12:21 AM
  #142
UniqueTII
UniqueTII's Avatar
I'm thinking that same thing...I plan on upgrading the rear bushings on the front LCAs to see if that helps. I just did the same thing to my Legacy GT as well.
Old 06-12-14, 09:27 AM
  #143
BNR34
BNR34's Avatar
What do you mean by upgrading? Polyurethane?
Old 06-12-14, 09:57 AM
  #144
Lavrishevo
Lavrishevo's Avatar
Yeah. Overall, poly has a bad rep in the LS400 and 430. Kills the ride quality. Especially in the front. The Roca bushings are not poly to my knowledge.
Old 06-12-14, 12:19 PM
  #145
BNR34
BNR34's Avatar
Thank you.
Polyurethane bushings definitely kills the ride quality, not to mention they make a squeaking noise, is ok on a race car, not on a luxury sedan like the LS.
Old 06-12-14, 07:30 PM
  #146
LEXLUIS
LEXLUIS's Avatar
wow amazing and great things to keep in mind on this post.
The bottom line is just a proper alignment, now I wonder how many shops have their equipment calibrated on a regular basis.
Old 06-16-14, 01:08 AM
  #147
UniqueTII
UniqueTII's Avatar
Yeah, I'm okay with a bit of NVH but if they're too bad I'll change them back. I have an IS350, but I still don't want too rough of a ride. I'll also be putting new tires on there because of the uneven wear on my Continental DWSes.
Old 07-29-14, 11:30 AM
  #148
e60bmw
e60bmw's Avatar
Do you guys think its necessary to take a UL with bags to the dealer for a allignment? I have a UL I just bought and it wanders to the right, it feels like its really out of alignment. How much does a alignment at the dealer run, maybe $120ish?
Old 07-29-14, 01:20 PM
  #149
Lavrishevo
Lavrishevo's Avatar
I don't think it is necessary to have the dealer do it but often they will price match. $80 - $100 is the going rate in my area.
Old 08-13-14, 01:58 AM
  #150
UniqueTII
UniqueTII's Avatar
I installed my LCA bushings along with new F Sport shocks and sways, had my new tires installed and had the car aligned and I'm still not happy with how this car tracks. Has anyone been able to come up with the alignment settings that will resolve this issue?
Quick Reply: Highway wandering
