IS-F / Sport Steering ECU
Old 02-18-12, 04:40 AM
  #91
yoegster
yoegster's Avatar
This is a great thread. Another mod to add to the list....
Old 02-18-12, 07:02 PM
  #92
Gville350
Gville350's Avatar
Originally Posted by Jeff Lange
As an owner of said ECU, I can confirm its awesomeness.
Jeff
Odd, when I looked up the P/Ns on Sewells site they didn't list a different one for the '11 & '12 ISF.
Plenty non-sports pkg 350 steering ecus on ebay...but nothing else. Will have to keep my eyes peeled.
Old 02-18-12, 10:01 PM
  #93
Nigel-JDMParts
Nigel-JDMParts's Avatar
That's not an entirely accurate list. This is though (for North America):
89650-53020 - 2006-08 IS250/350
89650-53060 - 2009 IS250/350 Sedan without Sport Package (Replaced by 89650-53061)
89650-53061 - 2010-12 IS250/350 Sedan without Sport Package
89650-53080 - 2009 IS250/350 Sedan with Sport/X-Package
89650-53081 - 2010 IS250/350 Sedan with Sport/F-Sport/X-Package
89650-53082 - 2011-12 IS250/350 Sedan with F-Sport Package
89650-53100 - 2010-12 IS250/350 Convertible
89650-53040 - 2008-10 IS F
89650-53041 - 2011-12 IS F
Do you know if the IS F one will be plug and play on 06 IS350? And is the JDM or USDM one are the same?
Old 02-19-12, 02:11 AM
  #94
Alantjai
Alantjai's Avatar
Nigel, the isf ecu will most likely work on 06 is350 as all isx50 &f ecu are interchangable.
I got the ecu from jeff (canada) and i live in europe with a euro is250.
All ecu's must be the same if the number is the same as the list.
Old 02-19-12, 07:34 AM
  #95
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
The IS F one should work fine on any ISx50.
RHD cars have the ECU mounted on the other side of the engine bay, so they have different brackets and part numbers. They might work, but I don't have enough information to say for sure.
Jeff
Old 02-19-12, 08:08 AM
  #96
Nigel-JDMParts
Thanks for the answer!! Is your euro is250 right hand drive too?
Jeff
Thanks Jeff!
Old 02-20-12, 01:06 PM
  #97
Alantjai
Alantjai's Avatar
Thanks Jeff!
I've got the Euro LHD, the RHD does have different bracket and ecu numbers... not sure about of just changing the bracket if they will work..
All LHD should have the same partnumbers like above and are interchangeable
Old 02-25-12, 05:19 PM
  #98
rog1206
rog1206's Avatar
Here's my update guys:
Just installed the 2011 ISF power steering ECU (89650-53041) on my 06 IS350 and without calibrating it, my power steering doesn't work at all. My P/S light isn't on and I'm not sure how long or if it will calibrate itself. I drove around some side streets for about 15 miles with 2 key on/key off cycles and there were no changes in the steering (as in no assist). I'll drive around some more for a few days and see if it gets better. If not, I'll have to go to a dealer or find a local person to get it calibrated.
Old 02-25-12, 06:05 PM
  #99
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Honestly I expected as much. When Alantjai did his, they were already used. A new ECU probably needs that initial calibration. It needs to know the parameters of the steering sensor, etc.
Jeff
Old 02-25-12, 07:54 PM
  #100
rog1206
rog1206's Avatar
Thanks Jeff. I guess I'll troll the boards and see if I can find a local tech who has access to Techstream.
Old 02-25-12, 07:56 PM
  #101
Sango
Sango's Avatar
I noticed you asked this in the Regional thread too!!
Old 03-05-12, 01:38 PM
  #102
viprtwo
viprtwo's Avatar
how much would the Lexus dealer charge to calibrate the ECU? Any other shops in so cal that can do this?
Old 04-13-12, 02:11 PM
  #103
viprtwo
viprtwo's Avatar
Hey guys, just an update to this thread,
I picked up steering control module 89650-53040 off the 2008-10 IS F and plan to install on my 06 IS350.
I'll let you all know if there's any difference between Power ECT and Normal
I'm really interested to figure out how much of a difference this is to either ecu below.
89650-53082 - 2011+ F-Sport
89650-53041 - 2011+ IS F
Old 04-13-12, 05:16 PM
  #104
TopGearLA
TopGearLA's Avatar
Hey Jeff,
I have a 2012 IS350 f-Sport, would this part be of any use to my car? If so what are the key differences I can expect? I'd imagine I'd be able to break mostly even after I sell the f-sport ecu since people are benefiting from that as well.
Old 04-16-12, 11:04 AM
  #105
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
It would simply be less steering assist, so stiffer steering and more road feel.
Jeff
Quick Reply: IS-F / Sport Steering ECU
