Old 12-12-14, 03:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
Rear Shocks need replacement on my 07 IS350
Old 12-19-11, 08:26 AM
kukuku23
kukuku23's Avatar
Default Rear Shocks need replacement on my 07 IS350
Are these the F-sport/Bilstein shocks that I need and will fit the 07 IS?
http://is.sewellparts.com/accessorie...2011/1801.html
Is the price pretty good and what are the prices that you guys pay for the parts and the labor as well? I got quoted $1200 at the Lexus dealer for just replacing the rears...
Also, I'm looking around the Lexus site for parts, why are the stock oem IS-F shocks (part #48510, 48520 $229.07 each for fronts, part#48530, 48540 $253.86 each for rears) different pricing than the link above? The part numbers for the link above are different as well (PTR13-53080, PTR13-53081, PTR13-53093, PTR13-53094)
Since only my rears need to be replaced, would you guys recommend me changing just the rears or all 4?
Please help, thank you
Old 12-19-11, 09:19 AM
Kurtz
Kurtz's Avatar
The F-sport shocks and IS-F OEM shocks are different prices and parts because they have nothing to do with each other.
F-sport parts are parts for the ISx50.
IS-F parts are for the IS-F, which despite many similarities, is also a different car.
If you're on stock springs I don't think I'd recommend doing anything but replacing the two bad shocks with OEM replacements... the F-sport parts would probably over-dampen the stock springs a bit.
I certainly wouldn't be putting different shocks front and rear on the stock springs.
If you like the stock suspension, just get 2 new stock shocks. If you don't, then you need to decide what exactly you want from the suspension and see if it's time for coilovers, or possibly a shock/spring change (again you'd want to do this on all 4 corners)
Old 12-19-11, 12:58 PM
Gville350
Gville350's Avatar
Depending on what you decide on what route to go with your parts here, might I recommend the DIY approach on the shocks? I mean, I just did install a set of BC Racing coilovers on my 350 over the weekend and rears were a BREEZE! Pull the carpet liners, jack up the car, remove wheel, remove sway bar end link (12mm), remove 19mm bolt through shock, remove 19mm LCA bolt attaching to the knuckle. LCA drops down. Now remove the 14mm top shock mount nuts...done! Now, if you are not doing a coilover setup you will have to put the OE spring on the new shock. Though this might be scary for a first-timer, its as simple as getting $20 set of the spring compressors from Harbor Freight.
Save the extra change and purchase more mods! LOL
Old 12-19-11, 07:26 PM
kukuku23
kukuku23's Avatar
so would it be ok to get the f-sport shocks to go with my oem springs?
or do I need to get these as well?
http://is.sewellparts.com/accessorie...2007/1800.html
Old 12-20-11, 02:07 PM
kukuku23
kukuku23's Avatar
are these the exact same as the oem shocks?
http://www.ebay.com/itm/TOKICO-REAR-...ht_4012wt_1041
Old 12-20-11, 02:52 PM
IS350HKS
IS350HKS's Avatar
I have 4 OEM Shock use less than 10,000 miles and a set of new f-sport springs. Let me know you are interested
Old 12-20-11, 03:06 PM
kukuku23
kukuku23's Avatar
how much are you looking for just the shocks?
Old 12-20-11, 04:15 PM
Sffd103
Fire Slayer
Sffd103's Avatar
I would either buy the other guys set on here, buy 2 stock shocks if you NEVER plan on lowering, or get the blue Tokico's for a beter deal and have someone other than the dealer install them.
Old 12-20-11, 06:05 PM
kukuku23
kukuku23's Avatar
Can someone please answer this for me.
Are the tokico blues the same as the OEM shocks? I need to replace just the rears, so I need to know if I can just buy 2 tokico blues for the rears.
Old 12-20-11, 06:57 PM
Gville350
Gville350's Avatar
The blues are probably the closest valved shock they have compared to OEM.
Old 12-20-11, 07:01 PM
VIS250P
VIS250P's Avatar
WhicH TX u live? If u live in local, I would charge u cheap for labor...
Old 12-21-11, 09:35 AM
kukuku23
kukuku23's Avatar
dallas.
VIS250P, do you know anyone with oem shocks in the area?
Old 02-25-14, 02:13 AM
Buya02
Buya02's Avatar
Default still got them
super old post, but do u still have the shocks?
Old 02-25-14, 10:08 AM
JETLEX
JETLEX's Avatar
I've still got mine for sale if anybody needs them - see fs link below:
(less than 3K miles - went to HTS adjustable shocks)
https://www.clublexus.com/forums/2ge...vleds-etc.html
onilink
Suspension and Brakes
03-28-15 09:04 AM
JETLEX
05-03-12 05:35 PM
hsk73
Suspension
06-03-11 09:17 AM
350PsDMeuP
08-10-10 09:53 AM
derfp2
Suspension
15
02-14-10 11:17 AM
Quick Reply: Rear Shocks need replacement on my 07 IS350
